Questions on intake manifold
  • Thread starter Thread starter GTA_V6_Mustang
  • Start date Start date Nov 8, 2011
GTA_V6_Mustang
1,326
Miami, FL
Nov 8, 2011
  • Nov 8, 2011
Ok well I finally got sick of my idle issues and oil leak from front lower intake and started pulling it apart tonight. For one found my vacuum leak, the rear ear on the upper intake is cracked right off. I need to decide now, its an edelbrock performer intake, should I try to get an rpm upper or just get this fixed at the machine shop. The current mods are the entire edelbrock performer power package (hci) long tubes, o/r x, magna packs, and 150 shot, on motor it made 302/322, with an off the shelf tune. I would of course like to get a bit more out of it on motor or should I just leave it be? What do you guys think?
wythors
Get off my lawn!!!
2,277
35
69
C Addle
Nov 9, 2011
  • Nov 9, 2011
If it was me, I'd just get it welded back together, unless I had $400 burning a hole in my pocket.
stykthyn
5,232
2,652
223
gainesville
Nov 9, 2011
  • Nov 9, 2011
Common placecfor it crack. I had tobweld that tab back on as well.
5spd GT
"the 5.0 owns all"
9,516
Arkansas
Nov 9, 2011
  • Nov 9, 2011
Same thing happened to me on the back right ear (facing the engine). The PCV connection joint was not screwed in enough on the intake and was hitting the valve cover when I torqued it down - snap!
It was a $40 fix at the machine shop. They had to mill it slightly to make it true again.
What symptoms did you have from the vacuum leak?
GTA_V6_Mustang
1,326
Miami, FL
Nov 9, 2011
  • Nov 9, 2011
Well its not my dd so I have plenty of time to let it sit in my garage while I gather the parts. But if its not going to be a noticeable difference, ill just keep this intake on there. And yeah my guy at the machine shop said he could take care of it for me so not worried about being able to fix that.
K
Resolved Need some assistance. Holley Terminator X alongside H/C/I. Very rough/inconsistent idle
  • karhoot
  • Jun 6, 2026
Fox 5.0 Mustang Tech Jun 6, 2026
karhoot
K
351W/5.8 EFI intake manifolds fading away...
  • Ryno5150
  • Jan 13, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 7, 2026
nickyb
E
Chasing Vacuum leak 99 GT
  • EBNS_2005
  • May 2, 2026
1996 - 2004 SN95 Mustang -General/Talk- May 3, 2026
X-cam34
H
Engine 1987 5.0 HO vacuum hose locations
  • harryhaber
  • Jun 20, 2025
Fox 5.0 Mustang Tech Jun 21, 2025
limp
N
Edelbrock 1405 Setup
  • nathantaylor200
  • Nov 4, 2025
Classic Mustang Specific Tech Nov 5, 2025
nathantaylor200
N
