I have a 94 and had just sent my pro-m 77mm to professional mass air systems (formally pro-m) to get recalibrated for my 30lb injectors. I believe these are 30lb because they are red. Here is my problem. I install factory meter on and go into my tweecer and tell it to run stock meter with 30 lb injectors. The car idles fine until you take off and put load on it. At this point it goes way lean. It will idle fine and even if you rev it up it will run fine. I fussed with different meter files and had no luck. I even tried richening the meter and still no luck. Finally I told it to run 36lb injectors. Bam, it runs! It doesnt run perfect but it does run and stays consistently around 14-15 in a/f. Can anyone explain why this is? I was thinking maybe I was wrong and actually had 36lb injectors but called the company who is recalibrating and said these are 30. So what gives?
