Hello im 17 and i just bought my car i was wondering about a few things....how much does the smaller underdrive pulleys add to ur car?...what kinda of breather should i run im using a foam elbrock one now i heard there no good...i was thinkin of the brute force....should i stick wit bbk shortty headers or go long tube whats the best exhgasut system i should use i got flowmatsers on it now...any opeans on how to amke it run better would be grealy appreated heres the list of whats done to my motor...
Specs: MSD 6AL ignition. Holley electric fuel pump with regulator and fuel pressure gauge. Autometer monster tach with shiftlight. Hurst short throw shifter. Brand new SVO 410 gears. bbk shorty headers. h-pipe. Flowmaster mufflers. Lakewood lower control arms.car is frame connected and also has driveshaft loop.car ran 12.08 at 111 mph with 1.90 60 ft.
Custom three color paint job. 16" pony rims. 351 Windsor motor.
Bored 40 over, flattop pistons, Comp Cams 280s solid lift cam 1970 351 Windsor heads, fully polished and ported, new valves, springs, locks, rollertip rockers, guide plates, hardened pushrods. Holley street dominator single plane intake.
Holley 750 dual feed double pumper carb. 5 speed trans. Ford KING COBRA SVO clutch. Hays fully adjustable clutch cable.
Autometer Oil Pressure and water tempature gauges in dual Pillar Pod
