1994 Cobra modified n2o 5.0 white/black $4500
birel21y
Reno, Nv
Ok. NOW $4500. I need it gone. I dont want to part it out. Im in North Seattle, WA
Call Alex. 775-351-3542
1994 mustang cobra #283 of 5009 cobra's produced in 1994. Included in sale is genuine SVT authenticity certificate. Years of work into this project, but im moving on to new projects. This car has been gone through and almost everything has been replaced with after market parts. Last march the engine was replaced, engine bay re-pained, full wire tuck done, and carbon fiber plates installed throughout. SEE BUILD THREAD ON C.L. LINK
Needs to be tuned.
Needs some paint work. Scratches on some places on car, and front fender was replaced and paint does not match perfect to hood and fender.
Engine:
Low Miles (est. 70-80K) 180-190 even compression on all 8
Crane 2040 PowerMax Cam
Crane Cams Adjustable Ignition System With Adjustable Launch Control (2 Step 900-9900 RPMS)
Launch control is triggered by "off" button on steering wheel.
Adjustable in-car timing retard (for nitrous, supercharger, etc.)
24 lb injectors
Ported gt-40 "P" heads
NGK TR55 plugs
Trick flow valve springs
fms push rods
FMS lifters
FMS valve covers
1" phenomic spacer
TFS Track Heat intake
24lb injectors
75mm bbk throttle body
Custom cold air intake
optima yellow top battery (mounted in trunk)
Summit aluminum battery box
75mm mass air
underdrive pulleys
air pump / egr delete
findanza 13lb. billet aluminum flywheel
centerforce dual friction clutch
Proform 7qt. oil pan
meling high vol. oil pump
Trick Flow 75-150 shot plenum plate nitrous system with TFS bottle, etc.
Exhaust:
Fully heat wrapped Headman Longtubes
BBK x-pipe (modified catted x-pipe included for smog)
Borla XR-1 Catback with intercooled tips
New O2's
Interior:
Full 2004 Mach 1 interior (seats-(custom embroidered with"SVT" , carpet, gauge bezel, middle console.)
Kenny Brown Super Street 6 point Roll cage
Alpine speakers
Pioneer deck
ford racing/ autometer phantom gauges (4)
Suspension/Brakes/Wheels:
2004 mach 1 rear end with 355:1 gears
Urethane bushings throughout entire car
Suspension Techniques BIG front sway bar
Tokiko Front struts
Koni yellow rear shocks
New ball joints
03 cobra a-arms
Eibach pro kit springs
Powerstop crossdrilled/slotted/vented front+ rear rotors
Red 25th ann. 2003 cobra Brakes (NEW)
New Pads
17x9F- 17x9.6R Rota P45R Flat black/Red stripe wheels (1st mustang Ive seen with these)
Exterior:
Saleen T-1 Wing
2.5 Cowl Heat extract Carbon fiber hood Custom made by my order
Genuine Saleen side skirts+ door fillers(off car- Included)
