Questions on New MCLeod Clutch
01LaserRedCobra
318
I am probably going to get a McLeod Clutch installed while my tranny is getting the TSB fix for the 1-2 grind that is going on.
My questions is
1. Are the McCleod Clutches good
2. Is it necessary to get a new fly wheel with a new clutch or can you use the existing one? Or is it necessary to get in re-surfaced.
Thanks,
I like mine - got the 800 series and matching pressure plate. Pedal is a little firmer, drivability is about the same, but it really grabs! Your flywheel would need to be resurfaced. Might as well upgrade the cable & quadrant, and install a firewall adjuster too.
