I'm planning on replacing my catted MRT H for UPR o/r X this weekend just for a change. I originally had the MRT pipe and a pair of flows put in by a muffler shop. I had a couple questions about the install....
1. As far as the replacement between the two pipe should be a pretty even match (ie, unbolt, pull off, put he new pipe on, bolt in)?
2. If not, anything I should watch out for?
3. I ordered a pair of mil eliminators as well. There's two of them. They should be here by tomorrow. I assume they go in the back two bungs. Is this correct?
4. What do I do with the front two sensors?
5. Can anyone point me to a write up to following on replacing the pipe (just for referenced) or at least the tools needed to be able to reach the bolth attached to the headers?
6. I'm only going to lift the front end to do this. Hope it's enough.
Anyway, I'm pretty hyped. Any thoughts or suggestions are greatly appreciated.
Thanks
Thanks
