Well I began to mess around with the Speedhut gauges today before I lost sunlight and gave up leaving the car like this...
http://i295.photobucket.com/albums/mm142/thealmightyhubbard/IMG_1435.jpg
Initially I planned on running my cluster and the AC panel gauge off of one inverter but they're kind of dim when rigged as such. First off, does this brightness look correct? This is maxxed out, one set plugged in at a time. Any issues running both inverters off the headlight switch so these only come on when I run my headlights? No need to have the AC panel glowing during the day.
http://i295.photobucket.com/albums/mm142/thealmightyhubbard/IMG_1431.jpg
http://i295.photobucket.com/albums/mm142/thealmightyhubbard/IMG_1430.jpg
This is how I currently have it wired.
http://i295.photobucket.com/albums/mm142/thealmightyhubbard/IMG_1436.jpg
I just twisted the red wire around the wire going into the headlight switch and plugged it back in, then ran the ground behind the ODB connection.
http://i295.photobucket.com/albums/mm142/thealmightyhubbard/IMG_1437.jpg
Suitable ground?
Is it normal for the inverter to whine a little bit? It doesn't whine at all when the switch is set to green but when I flip it to blue the gauges get brighter and it starts whining subtly. The green switch position is too dim.
The wire I tapped into provides power when the switch is pulled halfway out (fog lights/amber corners). I'm thinking about going straight into the headlights/low beams since these aren't as bright as I thought they were so I probably won't use illumination while driving with just my amber corners on because it's obviously not too dark out if I'm not using headlights and probably won't be able to see the backlighting anyways.
I tested and got 12.5v from that source.
Suitable ground?
