Questions-Why when I disconnect the air meter sensor nothing changes? this normal?
gruvee87vertgt
Oct 7, 2003
272
26
28
Chicago, Il
Well, my stang is running like crap. trying to pinpoint it.
I disconnected the plug that connects to the mass air meter and nothing changed...it's didn't run better or worse. is this normal or is my sensor not working? thanx
also it's backfiring and running rich after installing the distributor.
Dump the codes and see what the computer says is wrong…
Here's the link to dump the computer codes with only a jumper wire or paper clip and the check engine light, or test light or voltmeter. I’ve used it for years, and it works great.
See http://www.troublecodes.net/Ford/
OR
See http://www.mustangworks.com/articles/electronics/eec-iv_codes.html
IF your car is an 86-88 stang, you'll have to use the test lamp or voltmeter method. There is no functional check engine light on the 86-88's except possibly the Cali Mass Air cars.
For those who are intimidated by all the wires & connections, see http://www.actron.com/product_detail.php?pid=16153 for what a typical hand scanner looks like. Normal retail price is about $30 or so at AutoZone or Walmart.
Or for a nicer scanner see http://www.midwayautosupply.com/detailedproductdescription.asp?3829 – It has a 3 digit LCD display so that you don’t have to count flashes or beeps.. Cost is $35.
Pulling codes should always be your first diagnosis step.
If the problem started after replacing the dist though, then that is probably the issue.
Maybe, you are 180 off or just need to adjust the timing?
Just some thoughts, good luck :nice:
jason
