Questions
  • Thread starter Thread starter slow5.0gt
  • Start date Start date Aug 12, 2006
slow5.0gt
138
  • Aug 12, 2006
Should I plug this hose from the intake back into the fuel reg.? If the fuel pressure is at 50 when at startup/idle the rpms dont jump from 600-1200 however it "bogs?" [BangHead] [BangHead] [BangHead] whenever I try to go 1st and 2nd like its getting too much fuel I lower it back down and it wont have that problem but the rpms jump back and forth again... however after about 10 mins of warming it stops doing that... :-? :-? View attachment 448817
Does anyone know what this is? Its just below the disturbtor cap.
I am concluding that igintion has a part to play in the surging i feel at low throttle and at half/wot it backfires every once in a while just totally random [Crazy] gah!.....
[Help] [Help] [Help] :-? :-?
I
iwashmycar
20+ Year Stangneter
Apr 7, 2004
1,236
Columbus, Ohio
Aug 12, 2006
  • Aug 12, 2006
well that one thing is the spout connector....you take it out to set base timing and such
pb_paulie_b
894
Chaptico, Maryland
Aug 12, 2006
  • Aug 12, 2006
Leave the spout connector connected unless your checking your timing a adjusting your distributor. Removing it will stop the computer from advancing the timing and you car will run like crap.
HISSIN50
34
129
Aug 12, 2006
  • Aug 12, 2006
Welcome to the boards!
You want the FPR to a have manifold vac line attached to it. Otherwise, the puter gets confused because it's not seeing fuel pressure fall when not at WOT.
Good luck.
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Aug 12, 2006
  • Aug 12, 2006
Re-connect the vacuum line to the fuel pressure regulator.
Dump the codes and see what the computer says is wrong…Codes may be present in the computer even if the Check Engine light isn’t on.
Here's the link to dump the computer codes with only a jumper wire or paper clip and the check engine light, or test light or voltmeter. I’ve used it for years, and it works great.
See http://www.troublecodes.net/Ford/
OR [[
See http://www.mustangworks.com/articles/electronics/eec-iv_codes.html
IF your car is an 86-88 stang, you'll have to use the test lamp or voltmeter method. There is no functional check engine light on the 86-88's except possibly the Cali Mass Air cars.
For those who are intimidated by all the wires & connections, see http://www.actron.com/product_detail.php?pid=16153 for what a typical hand scanner looks like. Normal retail price is about $30 or so at AutoZone or Walmart.
Or for a nicer scanner see http://www.midwayautosupply.com/detailedproductdescription.asp?3829 – It has a 3 digit LCD display so that you don’t have to count flashes or beeps.. Cost is $35.
See "Help me create the Surging Idle Checklist" at http://forums.stangnet.com/showthread.php?t=534062
for help with your idle problems. The first post contains all the updates to the fixes. I continue to update it as more people post fixes or ask questions.
vristang
4,933
101
124
Seattle
Aug 12, 2006
  • Aug 12, 2006
^^^All well stated.
And, welcome to Stangnet.
The fuel pressure should be 38-40psi at idle with the vac line disconnected. It sounds like your a little high at 50psi.
But like JT stated, you do want to plug it back in after checking the pressure.
jason
slow5.0gt
138
  • Aug 12, 2006
thnx for the welcomes! i get alot more responses faster then on SVT
I have the fuel pressure guage hooked up to the rail so I see how much pressure im running
however that screw should be removed correct? thats how I adjust the fuel pressure from 20-60 and such removing it wont have an affect since it will be running off the vacuum now correct?
Sorry for all the questions I just have never used a fuel reg. before.
slow5.0gt
138
  • Aug 14, 2006
ttt....!
vristang
4,933
101
124
Seattle
Aug 14, 2006
  • Aug 14, 2006
The normal running state for the regulator is to have the vac line hooked up.
To check/adjust the pressure
-Start the engine and let it idle
-With the engine at an idle, pull the vac line and plug it (as shown in your pic using a screw).
-With the vac line disconnected the fuel pressure should be 38-40psi.
-When done checking/adjusting the pressure, hook the vac line back up.
-The car is now ready to drive.
:Word:
slow5.0gt
138
#10
  • Aug 14, 2006
  • #10
leave the adjuster screw in the regulator? or remove both?
slow5.0gt
138
#11
  • Aug 15, 2006
  • #11
ttt.....
vristang
4,933
101
124
Seattle
Aug 15, 2006
#12
  • Aug 15, 2006
  • #12
Wow.
I didn't even see the screw in the regulator.
I would say to pull that sucker out.
It appears that you have a stock regulator, which is not adjustable. In other words, that screw has no business being there.
I don't know if the screw in the regulator could have damaged it or not. Watch for fuel coming out of that nipple when you remove the screw.
If you see fuel then you will need to replace the regulator.
Saleen0679
876
24
49
Yakima, WA
Aug 15, 2006
#13
  • Aug 15, 2006
  • #13
I don't think that is a stock regulator. It looked familiar so I did some digging. It looks like a Holley 512-500-1 seen http://www.holley.com/512-500-1.asp. The screw on top is the pressure adjustment screw, but I haven't seen a picture that shows a provision for the vacuum line. Even the instructions http://www.holley.com/data/Products/Technical/199R10017-1.pdf for that regulator do not mention the vac line.
vristang
4,933
101
124
Seattle
Aug 15, 2006
#14
  • Aug 15, 2006
  • #14
Holy Research, Batman!
Good Find!
:SNSign:
I don't imagine there is a hole through the middle of that set screw on the regulator, is there?
If so, then just slip the vac line over the adjuster screw and your done.
You might want to ensure that the vac line is not stretched out from being plugged with the big screw.
jason
slow5.0gt
138
#15
  • Aug 15, 2006
  • #15
yes it is the holley reg. no there isnt a hole in the screw so putting the vac line over it wouldnt make it adjust at all correct?
310stanger
170
#16
  • Aug 15, 2006
  • #16
jus a suggestion, i dont know if anyone else here agrees, but the fuel pressue at 50 psi is a bit high? i know mine is set at around 39. im saying this knowing nothing about the rest of your combo though.
vristang
4,933
101
124
Seattle
Aug 15, 2006
#17
  • Aug 15, 2006
  • #17
I would suggest to contact Holley.
I have no idea how this regulator works?
I must admit that I am wothless at this point.
Please let us know what you find out though,
jason
slow5.0gt
138
#18
  • Aug 16, 2006
  • #18
I talked to the tech at holley and he said to plug the vac line in so that at WOT and at low throttle it will compenstate because if not it will just stay a constant PSI since its set by the adjustor screw. So here it goes!
1999 Mustang GT - No Start- Need help understanding the fuel pump circuit and how it works
  • 99gtGuy
  • Nov 4, 2025
1996 - 2004 SN95 Mustang -General/Talk- Nov 7, 2025
04newedge-
Help with AFR reading
  • dz01
  • Nov 14, 2024
1965 - 1973 Classic Mustangs -General/Talk- Jan 8, 2025
GOvert
G
Car idles good, then VERY SUDDENLY dies
  • Vulpes5.0
  • Jan 17, 2024
5K
Fox 5.0 Mustang Tech Feb 4, 2024
Vulpes5.0
Electrical SUDDENLY FUEL PUMP SHUTTING OFF RANDOMLY
  • PonyGTrider
  • Nov 7, 2023
6K
Fox 5.0 Mustang Tech Feb 10, 2024
Mindseye007
Progress Thread H/C Swap Problems/Ideas
  • sav22rem22
  • Mar 31, 2024
2K
Fox 5.0 Mustang Tech Sep 10, 2024
AeroCoupe
