Quick 351w question
  • Thread starter Thread starter Hotrodsun
  • Start date Start date Sep 2, 2004
H
Hotrodsun
58
Salem, OR
Sep 2, 2004
  • Sep 2, 2004
I was wondering about how much horse power you can make before the block would fail? I know 600hp is about max for the 302 before is cracks the block, so how about the 351W? Thanks, Adam
J
Jason@AFR
58
California
Sep 2, 2004
  • Sep 2, 2004
I have heard of a few guys in the 700+ range, but I would rather buy a better block for that area, they all know they are on borrowed time. I would personally say that with only a 0.030" bore in the neighborhood of 650-700 MAX, for a short while, definitely a short while.
just MHO
5.0 HOtrain
2,247
New Hampshire
Sep 2, 2004
  • Sep 2, 2004
69-74 blocks are the strongest.
With 69' being the strongest. A good machine/balance job/ and tune up are the most critical things to how long a engine will last. I have a 69' block that is hardblocked up to the water pump, a steel girdle,and a good array of parts, it makes almost 600 at the crank n/a and I would not be scared to put a 150hp shot of nitrous on it.
mike.
giddyup306
3,041
Sep 2, 2004
  • Sep 2, 2004
A stock 302 block won't take 600.Might hold up with one pass. Max is about 450 and your running on borrowed time. 600 is where I'd limit a windsor block if not too much is taken from the cylinder walls.
9
93notchspray
87
blacklick ohio
Sep 2, 2004
  • Sep 2, 2004
i have a 69 block and i just got it dynoed it made 608hp and 580 ft torque. it is studded and girdled. plus i will be putting a 250 shot through her. hope it stays together
H
Hotrodsun
58
Salem, OR
Sep 2, 2004
  • Sep 2, 2004
Cool guys. I heard over at turbostang about the 600 crack hp thing. I was thinking in the 500-550hp range with a 94 roller block. I can get a used 351w with 63k miles on it for $550.00 from a local wreaking yard. Thanks for the info, Adam
408stroker5.0
The world would be a better place if all males jus
Mar 10, 2004
639
Bonnyville, Alberta, CANADA
Sep 2, 2004
  • Sep 2, 2004
Using a .30 69' Block, with all the proper machining done and with the use of a good quality main Stud Girdle, 700HP at the flywheel is pretty much the maximum I'd think.
Shon
Ford truck engine swap issues
  • keel
  • Jul 7, 2026
  • Other Auto Tech
Other Auto Tech Jul 13, 2026
General karthief
Engine Forged flat top pistons from 5.0 fit a 351 build?
  • PonyGTrider
  • May 22, 2025
2K
Fox 5.0 Mustang Tech Feb 1, 2026
PonyGTrider
D
Engine HO cam in non HO roller block ‘93 f150
  • DanC1993f150
  • Mar 21, 2026
Fox 5.0 Mustang Tech Mar 29, 2026
General karthief
A
Blow through intercooled questions
  • AngryH58
  • Aug 31, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sep 1, 2026
AngryH58
A
J
Suspension Foxbody mustang Steering shaft issue
  • Jakub2537
  • Sep 5, 2026
Fox 5.0 Mustang Tech Sep 11, 2026
gkomo
