Quick 351W question
  • Thread starter Thread starter nick6704
  • Start date Start date Jun 18, 2005
N
nick6704
47
  • Jun 18, 2005
I have a '69 Mach 1 with the 351W engine, and I was wondering what the combustion chamber volume is on the stock heads? I can't seem to find out on google or searching the forum. Thanks.
rbohm
6,698
550
204
tucson,az
Jun 19, 2005
  • Jun 19, 2005
as i recall they run between 64 and 68 cc's on the early heads. later ones went as much as 77 cc's
C
cobraii351
1,104
Altoona, PA
Jun 19, 2005
  • Jun 19, 2005
Going by the books, the 69-70 windsor heads were 60.4 cc's.
69Rcode_Mach1
1,473
Salt Lake City, Utah
Jun 19, 2005
  • Jun 19, 2005
Cobraii351 is right if they are the C9AE or the D00E heads they have the 60.4cc combutsion chambers.
1320stang
4,329
23
89
Edmond, Oklahoma
Jun 20, 2005
  • Jun 20, 2005
I'm going to say in the range of 60-64cc. I know what the book says, but I also know of FE heads that were cast in the same places around the same time and they vary by about 4cc as well. Almost never smaller than advertised, 99% of the time they're bigger than smaller. Typically the chambers are all within .4-.5cc of each other at worst.
J
jbuening
399
Jun 21, 2005
  • Jun 21, 2005
Also don't fall for the trick of 4V heads vs 2V heads. They are the same heads. The 4V motors had flat top pistons thus increasing compression ratio, whereas the 2V had the valve reliefs. Just an FYI
C
cougar694u
145
San Antonio, TX
Jun 21, 2005
  • Jun 21, 2005
That's good to know. I thought the 4v heads had bigger ports as well.
Max Power
1,774
St Paul
Jun 21, 2005
  • Jun 21, 2005
Only on Clevelands.
Ford truck engine swap issues
  • keel
  • Jul 7, 2026
  • Other Auto Tech
Other Auto Tech Jul 13, 2026
General karthief
Engine (EGR Deleted) Solution the hotter combustion chambers?
  • PonyGTrider
  • Jan 21, 2026
  • 3 4 5
4K
Fox 5.0 Mustang Tech May 2, 2026
PonyGTrider
Autolite 3925 discontinued?
  • 387lx
  • Jan 29, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 30, 2026
Mustang5L5
New Exhaust for 408w stroker
  • SadbutTrue
  • Sep 10, 2026
1965 - 1973 Classic Mustangs -General/Talk- Sep 10, 2026
nickyb
N
Looking for ECU/CHIP for 1992 5.0
  • Nathan26
  • Sep 26, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 8, 2026
Qtrhrse23
