  • SN95 4.6L Mustang Tech
quick blower questions!
  • Thread starter Thread starter ADRENLN
  • Start date Start date May 18, 2005
ADRENLN
2,342
NJ
May 18, 2005
  • May 18, 2005
not that im ready to do it yet, but i was wondering at what psi does pump gas start to become a factor.
im not really clear on all the things for a blower. i want to stay on pump gas with no problems. however if get the vt built engine and novi2000 i want to make the best of the setup i have chosen. so is there a set psi not to go over if you want to stay on pump gas?
also i read that fuel injectors over a certain sive( i think 30) will cause problems with passing emissions.
basically a street car, want to pass sniffer, and run good on pump gas. what can i get away with?
300bhp/ton
530
England
May 19, 2005
  • May 19, 2005
afraid there is no definitive answer here.
1. What pump gas? As there are many octane ratings 87, 91, 93 and probably more.
Also you need to check which octane rating system you are refering to:
-RON
-MON
-PON
In the UK petrol is rated on the RON system whereas usually in the US it is rated on the PON system. However it worth checking as 95RON is about the same as 91PON.
2. The reason I say this is as far as my understanding goes FI is all about detonation. You need to be able to keep your Air/Fuel ratio within set bounds else you will have problems.
The more psi then the more octane is needed to control the A/F. KB reckon you should be able to safly run 9psi with 91PON fuel but for a more agressive tune (and safer) 93PON would be better still. This will take the standard block to about its limits (400-450bhp crank).
Using 100PON fuel over 500rwhp is possible @ 14psi but you are in real danger of it going bang. However this would more likly be due to the limitations of the engine internals, forged internals on a built block would handle it but with the stock CR 100PON fuel would still be a MUST.
The other alternative is to lower the CR of your engine, this will then allow you to run higher psi's on the lower grade fuels and still control the A/F. Ultimatley a low CR engine will make less power at the same psi but because it can safely run higher psi's they can produce more power.
Hence a built 2v 4.6 can rival a DOHC 4.6 Cobra for power even though the SOHC is less technically advanced.
3. If it turbo route you are going then the same problems exsist to an extent. But you will find that ALL mainstream production turbocharged engines run very low CR's and then usually quite high psi levels. There are a few reasons for this, reliability and also because a turbo affects the resistance in the exhaust where a s/c doesn't.
The down side to a low CR is that off boost the engine will have very little power, this in turn then exagerates the feeling of 'turbo lag'.
A light pressure turbo (6psi??) on a V8 with a fairly high CR will not produce massive PEAK bhp numbers but should provide good power most of the time and not feel as if its bogged down off boost.
For this reason IMO a supercharger is the much better aftermarket addon, as you can get good power and driveability from the engine as it is now.
A turbo setup will require much more work and R&D to work as well but will certainly cost more. If done correctly however I'm sure it would be awsome, but then again so is a good s/c setup.
Remeber PEAK numbers won't mean you have the fastest car, even more so on the street. What you want is usable power across the entire rev range with a broad power band. Take a look and research your options, The Roots s/c is not as bad as many think, as it does provide good power increases but more importantly it produces where you want it - low down in the rev range. The twin screw setup does exactly the same as the Roots but requires less power to run it (increase in net gain) and delivers air at a lower temp to the engine (bigger bang - more power), so the gains you get behind the wheel are likly to be 10-20% with a twin screw over the Roots. Centrifugal s/c's are taken from the aviation industry and are basically a belt driven turbo. They have the capability to produce the highest PEAK numbers of all of the s/c's. But it comes at a price, they produce very little power down low, even in the mid range rpm's they will still struggle to match a Roots blower for output and be way behind the twin screw. Once up in the higher rpms though . BUT it is likley that a centrifugal will only produce slightly more HP than a twin screw over the last 2000rpm, where the twin screw will produce significantly more power the rest of the time.
So the question is, how often are you going to spend at the red line compared to using the rest of rev range. If you have a gun hoe WOT style of driving then the Centrifugal will be for you, however is you just want instant POWER at any time no matter the rpms of gear you are in then a twin screw really is the only answer. As it will produce the most power most of the time .
01SN8K
135
  • May 19, 2005
there are some factors to consider, intercooling, climate, elevation and compression. best bet with a paxton blower w/91 or 93 octane is about 10psi to be reliable and emissions friendly but also depends on the cars tune. you may get more boost and still be ok but most street cars stay at about 10psi
ADRENLN
2,342
NJ
May 19, 2005
  • May 19, 2005
thanks guys very good info. i will read it over a couple of times. i could possably get a blower sooner then i think, if i get lucky. anyway i know there are alot of things to consider.
i am not afraid of blowing it up as i will be getting a built engine and a tune when the blower goes on.
i just wanted to know if 93 octain would be enough to run 12 or 14 psi.
i just wanted a little more then the average street car. if i have to stick to 10 psi to run street gas i will, but i wanted to take advantage of the novi2000.
only concern about injectors was passing the sniffer. you guys with bigger then 30 injectors pass ???????
ADRENLN
2,342
NJ
May 19, 2005
  • May 19, 2005
oh i forgot, one more thing. i will also have the mods in my sig coupled with foxlake ported heads (stage 2) no cams/using stock pi. i will also have a p 51 intake before the blower goes on. so my rwhp will be higher then a gt with the paxton at10 psi and not many other mods.
i assume my power level will be between 420-480 depending on tune... wil rwhp effect the pump gass, or is it just psi?
M
01 mustang 3.8 fuel pressure issue
  • Mhaley2006
  • May 29, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 9, 2026
JohnKay
J
'03 GT Fuel Pump/Pressure/Delivery Issue
  • Brodach
  • Oct 21, 2025
SN95 4.6L Mustang Tech Oct 31, 2025
gkomo
F
Ford 460 swap
  • Ford460
  • Sep 13, 2026
Ford460
F
D
03 mustang Mach 1, 4.6L None Supercharge
  • DangStitches
  • May 18, 2025
1996 - 2004 SN95 Mustang -General/Talk- May 23, 2025
Engine 1990 LX 5.0L EFI Mustang Fuel Management Problems - HELP!
  • 5.0LXStanger
  • May 25, 2025
  • 2 3
3K
Fox 5.0 Mustang Tech Jul 11, 2025
5.0LXStanger
