I have been looking at a new clutch since i have the motor out of the car, but Ads dont specify 6 or 8 bolt. Is this only for the flywheel, and then the 99-04 is the same clutch as long as its 10.5 or 11 depending on ur flywheel.
The 6 or 8 bolt is for the flywheels. 96- should have the same clutch, as long as its the same T45 transmission. Or T3650 if you're newer. Good luck! GT clutches are 10.5" Cobras are 11"
99-00 gt's has a 8 bolt flywheel 01-04 has a 6-bolt
and no they are not the same if your car has a t-3650 you need a 11 inch clutch the spline is the same but it has too be 11 inches. if you have a 99,01 cobra you need a 11 inch clutch too..
