quick combo questions
Alright this is a lot of stuff so im going to take it from the top.
This friday im ordering the parts.
As far as engine and fuel. Ill be going with the fallowing
Trick flow track heat o-ringed heads
Eddlebrock rpm 2 intake
COMP Cams Ultra Gold Aluminum Rocker Arms
255 fuel pump
24 pound injectors
adjustable fuel pressure regulator
Since the car Is NOT tuneable, will i have any trouble running this set up?
I had 2 shops look at it, and scan it but their is no signal. After I fix this ill consider a cam and FI
No o-ringed heads, they are more a pita than anything on a street car.
You may want to dial the intake back one notch to the edelbrock rpm, the rpm is better for strokers or superchargers. With the II you will give up some low end, that may not make for the best street drving.
Add the 70mm tb and spacer,
New timing chain, and water pump. Don't re-use the old crap while you got it apart.
do yourself a favor and buy the heads from someone like camshaft innovations. because you will get the valvesprings you need, and itll have a valvejob and a handblend of the valvejob into the bowl. this will pick up flow and power.
as far as the intake and low end, that also depends on what cam is used. if it were mine id use a systemax if i HAD to use a longrunner. my JY shortblock NA project is getting a spyder.
Thanks i appreceate your help
heres the new mod list
86-93 WATER PUMP, VICTOR SERIES HIGH VOLUME, SMALL BLOCK FORD......... 160
85-95 TIMING CHAIN SET, 5.0/5.8L, MAGNUM DOUBLE ROLLER.......................... 40
Cylinder Head, Track Heat - Small Block Ford Aluminum, Non O-Ringed With Upgrade Spring .................................................................................................1320
eddlebrock performer intake...............................................................................600
24pound injector.................................................................................................190
bbk 86-93 Throttle Body, 70Mm...........................................................................200
bbk 70mm egr spacer...........................................................................................60
86-97bbk Fuel Pump, 255 Lph, 4.6/5.0 Gt......................................................... 129
bbk fuel pressure regulator................................................................................ 100
Gasket Set, Head & Valve Cover - 5.0L/5.8L......................................................100
86-95 Gasket Set, Intake Manifold................................................................. 18.00
COMP Cams Ultra Gold Aluminum Rocker Arms.............................................270.00
trick flow Valve Covers, Standard Height - Black ......... 110
Stud kit....................25.00
3223 in engine and fuel
Sound good? I just need direct bolt on parts.. Are any of these not ??
First, i want to apologize, the performer rpm has been replaced by the rpm II, so there is no performer rpm, just the performer. I thought they added a new one (making 3), not replaced an old one.
So out of the two, i would get the rpm II.
Timing chain-ford racing with the key ways Ford Racing M-6268-A302 - Ford Racing Timing Chain Sets
Water pump, for racing, like $59Ford Racing M-8501-G351 - Ford Racing Mechanical Water Pumps
I also agree with clement, if it's in your budget get the heads already valve jobbed.
Consider these guys
Total Engine Airflow
You don't need them cnc'ed, all you need is a valve job, and bowl cleanup. By default they will also set the spring seat pressure.
Mine were done locally, but i have people i can trust within driving distance.
