urban96 bubb rubb says:"woo woooooo" Founding Member Sep 24, 2002 3,464 1 69 Syracuse, NY Jun 9, 2005 #1 Jun 9, 2005 #1 first time messing with the rear brakes... how do i detach the rear ebrake cable?
B bjam2 New Member Jun 20, 2003 94 0 0 Michigan Jun 9, 2005 #2 Jun 9, 2005 #2 Well you can do it correctly and loosen the tension at the e-brake handle inside or you can just use a screw driver to pull it off the spring at the caliper and reinstall it the same way.
urban96 bubb rubb says:"woo woooooo" Founding Member Sep 24, 2002 3,464 1 69 Syracuse, NY Jun 9, 2005 #3 Jun 9, 2005 #3 thanks.. ill go and give that a try
