  • SN95 4.6L Mustang Tech
Quick expertise please!!!!!!!!!!!!
  • Thread starter Thread starter Jack Powell
  • Start date Start date Dec 15, 2003
Jack Powell
284
Toronto, Canada
Dec 15, 2003
  • Dec 15, 2003
Ok i was wondering, i have been away for about 2 months haven' t started the car once. I live in Toronto so it is kinda cold. I have put the block heater on for about 2 days now. What should i do? Should i just start it?
Please any info would be good thanks
Jonathan Polakow :canflag: :canflag:
GotMustangs
390
Tacoma, WA
Dec 15, 2003
  • Dec 15, 2003
If your oil is close to when it needs to be changed, I'd go ahead and do that now before you start the car. I have been away from mine for a month before, and it just fired it up......no problems.
Jack Powell
284
Toronto, Canada
Dec 15, 2003
  • Dec 15, 2003
no the oil maybe has 50 km's at most like 30 miles. but is 2 months old.
mrvax
Stay thirsty my friends
SN Moderator: Orlando, Fl.
Dec 15, 2003
  • Dec 15, 2003
It should be fine.
Jack Powell
284
Toronto, Canada
Dec 15, 2003
  • Dec 15, 2003
hasnty the piston sat in the same spot for too long??? the oil has all fell to the bottom of the oil pan and not coated any of the parts???
NFCStang
127
Taking a leak in an SRT-4 gas tank
Dec 15, 2003
  • Dec 15, 2003
Start it up and let it warm up slighty at idle and just be gentle for the first 10 miles or so.
No matter how you slice it, he's gonna have to start it sometime and even if you change the oil it's still going to not be through the engine when it starts.
My dad stores his 94 vert and my bro's 83 vert from Nov-April and starts them right up. No biggie, but I know he changes the oil right after that and makes sure to put new gas in as well as injector cleaner
D
DC-GT
312
  • Dec 15, 2003
Keep in mind that there is no way 100% of the oil in your engine will drain to the bottom. Most oils also have additives that are designed to have "staying power". I would say you are fine unless you flushed or something prior to your last oil change 30 miles ago.
Bo
NasaGT
1,993
Virginia
Dec 15, 2003
  • Dec 15, 2003
Just start it up. Cars sit in the dealer lots for longer than two months without being started.
'03 GT Fuel Pump/Pressure/Delivery Issue
  • Brodach
  • Oct 21, 2025
SN95 4.6L Mustang Tech Oct 31, 2025
gkomo
P
Is it normal for all of this to go wrong or did I get played when I bought this ONLY A MONTH AGO.
  • ponygal02
  • Nov 14, 2025
1996 - 2004 SN95 Mustang -General/Talk- Nov 14, 2025
M
  • mnky99
  • Sep 5, 2025
mnky99
M
G
2006 Mustang GT o2 Sensor Wiring Issue Car Bogging/Choking
  • GCantero93
  • Sep 5, 2025
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Sep 6, 2025
  • dan50
  • Jul 18, 2026
dan50
