thumper460 said:Springs are important!! everything you do will turn to crap, with out the correct pressure!! tired and worn springs are ok.. but you know your are going to push it, so not counting the HP loss from weak seat pressure, or valve float.. get good springs! the heads are off.. the machine shop will do it and make al the pressures correct, there are some things you can skimp on, and then some you cant!! cool??
Just me.................................
Thumper
mrswivlepants said:What kind of 1/4 times do you get with your setup?
v8only said:it's not just you. My buddies harped on me so bad on this subject, thats why I ponied up for the tfs springs.
mrswivlepants said:Maybe you know, or someone else....will AFR springs work on these heads? Does it matter if they came off of a stud mount setup rather than a pedestal like the gt40ps? Someone educate me on springs and the valve train please.
thumper460 said:You buy a cam... you buy some heads.... gaskets... timing chain.... the hours to put it all together. Fire it up.. sounds good!! Make a few runs around the block.. feels good!! then the first run, you stack the valve springs... or lose the race 'cause the valve is bouncing on the seat and not holding power.. or worse.. you float the valve and hit the pistons and take out the whole freaking engine... why?? Cause you put in "should work springs" Make sure.!!. there are things you can skimp on... and things you cant!!
