  • 1994 - 1995 Specific Tech
quick head question ...351W
  • Thread starter Thread starter trav_19
  • Start date Start date Jul 21, 2007
trav_19
810
Jackson, MI
Jul 21, 2007
  • Jul 21, 2007
ok what would be a better head to start off with i will get a nice set later on but i want this motor together now lol ...carbed 351w..( no 408 yet ) would a older 351 head thats worked over be better or would a e7 head off of our cars thats worked over be better i thought someone said the e7's were a better design just want to make sure..thanks
The Green GT
No 13 year olds are safe around me.
1,269
Louisiana
Jul 21, 2007
  • Jul 21, 2007
If they are E5 heads then you are better off with E7's.
trav_19
810
Jackson, MI
Jul 21, 2007
  • Jul 21, 2007
all i know is they came on the block its a 69 i believe might be a 70 block
The Green GT
1,269
Louisiana
Jul 21, 2007
  • Jul 21, 2007
Do you have the numbers on them?
And that could very likely be E5's.
RFMustangGT
294
Knoxville,TN
Jul 21, 2007
  • Jul 21, 2007
some of the early 351w heads are high compression heads.
reddy351
560
12
38
Columbus, Ohio
Jul 21, 2007
  • Jul 21, 2007
Actually, the 69/70 351w blocks have a little less deck height. (About .080", I think.) So, the compression with any head will be higher with that block. (What are the casting numbers?) The 69/70 heads have smaller combustion chambers than the 72-up heads. That's why they used to have a great reputation with Ford guys. If you are able to do it, I'd at least swap on some GT40's or GT40p's on that block. Port them too, if you have the time. ALL of the OE Windsor heads were pretty crappy, as far as the ports are concerned. GT40's changed that, a little. (I think E7's are bad on a 302, let alone a 351.) Ported GT40's would be the minimum for a strong 351, IMO.
trav_19
810
Jackson, MI
Jul 22, 2007
  • Jul 22, 2007
ok my dads machine shop is able to port and polish and everything so i thought i could take a kinda crappy head and make it worth something for now...i will try to get the numbers the blocks not at my house its about a hour and a half away at the shop..not to sure when i will be back down there but i will look into it
R
Microsquirt tune for stroked 351W in a foxbody
  • roldy
  • Jul 26, 2026
  • Digital Self-tuning Forum
Digital Self-tuning Forum Aug 11, 2026
roldy
R
Engine Suggestions on an engine rebuild. Stock cam/GT40Ps or aftermarket on both for a fun weekend driver?
  • MadSquirrelTech
  • Apr 28, 2026
Fox 5.0 Mustang Tech May 7, 2026
MadSquirrelTech
K
Door post and rust repair
  • Kleinjj27
  • Aug 21, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 8, 2026
Kleinjj27
K
R
Progress Thread 351w stroker rotating assembly and build
  • Ric4eyedFox
  • Mar 23, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 24, 2025
Progress Thread 351w Build, 67 Coupe
  • redstang67
  • Oct 4, 2024
Classic Mustang Specific Tech Oct 5, 2024
89ripper
