  • 1994 - 1995 Specific Tech
quick help about harmonic balancer, please
  • Thread starter Thread starter droptopford 5 0
  • Start date Start date Jul 25, 2005
droptopford 5 0
427
Jul 25, 2005
  • Jul 25, 2005
i bought a ford racing 50 oz harmonic balancer to replace the stocker when i saw the rubber popping out the back. now that im in the middle of doing so, i notice the balancer hits the bottom of my water pump near the stud for the pump. so i grind down the bottom of the pump, but now im just wondering how much clearence i should have between the two... right now the clearance is about the thickness of two credit cards, what do you think is a safe clearance??.. i might be able to get another 32nd or 16th of an inch of clearence but i dont want to grind through to the stud threads, thanks
nmcgrawj
Advanced Member
Sep 28, 2003
3,651
Indianapolis, IN
Jul 25, 2005
  • Jul 25, 2005
hmmmmm....i have put on 2 or 3 autozone replacements and 2 romacs and none of them hit the water pump.
Are you positive its the correct balancer for the application?
On my romac, it hit the water pump pulley(underdrive set) so i took about a 1/16" off the back of the pulley and was good to go, but not the water pump itself.
Post up some pics if you can. Do u see any difference in the stock HB and the Ford Racing piece?
Y
yellow1995Cobra
2,959
Massachusetts
Jul 25, 2005
  • Jul 25, 2005
I had a fluidamper harmonic balancer at one point, and it hit the waterpump. Had to be ground down a tiny bit. I think the ammount u ground off will work out just fine.
droptopford 5 0
427
Jul 25, 2005
  • Jul 25, 2005
its just a "stock replacement" for 81-95 5.0 (different one than stock replacement for the 81-93 piece... wierd huh)or so it said according to mustangs unlimited, then i called them up and told them my problem, they said according to ford racing both of the balancers need modification for the 94-95's, so i just ground it down, just hoping its enough... whats done is done now, just put it all together and it seems to be ok, we'll see in a bit...oh yeah and to answer your question, it looks identical, even the size is almost exact from what i can tell without actually measuring it...
rustang94
281
Milwaukee WI.
Jul 25, 2005
  • Jul 25, 2005
What is the best harmonic balancer for our cars thanks
HISSIN50
34
129
Jul 25, 2005
  • Jul 25, 2005
If money is no object, it is hard to go wrong with a Romac IMHO.
For poor folks like myself, the PP street balancer for 80 bucks or so would be my choice.
Good luck.
rustang94
281
Milwaukee WI.
Jul 25, 2005
  • Jul 25, 2005
thanks
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Jun 20, 2026
gray owl
G
  • AeroCoupe
  • Aug 2, 2026
AeroCoupe
Wanting to replace my BOSS 351C Engine Harmonic Balancer - Questions about 'Balance?'
  • 69machmike
  • Oct 31, 2024
1965 - 1973 Classic Mustangs -General/Talk- Nov 5, 2024
Realmongo
  • dan50
  • Jul 18, 2026
dan50
Progress Thread "Alter Ego" White 1993 LX 5.0 5spd
  • idareu
  • Sep 9, 2024
  • 2 3
3K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 19, 2025
idareu
