6 '69Mach1Chick There's no grass left to cut. Apr 1, 2002 348 0 0 North Jersey Aug 2, 2004 #1 Aug 2, 2004 #1 what can i use to strip and prep my fiberglass scoop for epoxy?
DarkBuddha Founding Member Dec 11, 2001 2,215 1 47 Seattle & Tampa Aug 2, 2004 #2 Aug 2, 2004 #2 Sandpaper works well.
6 '69Mach1Chick There's no grass left to cut. Apr 1, 2002 348 0 0 North Jersey Aug 2, 2004 #3 Aug 2, 2004 #3 should i use a block...what grit.....wet/dry sanding????? Should i put the primer right on it? Will it look the sam as the rest of the car???
