  • SN95 4.6L Mustang Tech
quick lug nut question
  • Thread starter Thread starter blackink00
  • Start date Start date Sep 22, 2005
blackink00
I missed a shift & stole Curt's money.
Mar 30, 2005
545
Tempe, AZ
Sep 22, 2005
  • Sep 22, 2005
im getting some weld draglight 90 series rims and they require a shank style lugnut. can somebody tell me the right kind to get that'll fit our studs. its a 98 gt if that matters. thanks.
blackink00out
forpit2000gt
2,490
Columbia, SC
Sep 22, 2005
  • Sep 22, 2005
They are about 2 1/4 inch long, 1/2 x 20. AZ has them. make sure you get washers as well. Or get the lugs from where you purchased rims.
K
Kilgore Trout
Fried or Broiled ?
4,749
95
134
Sep 22, 2005
  • Sep 22, 2005
Mad Tyte Lug Nuts Yo
forpit2000gt
2,490
Columbia, SC
Sep 22, 2005
  • Sep 22, 2005
http://www.jegs.com/cgi-bin/ncommerce3/ProductDisplay?prrfnbr=4048&prmenbr=361
here is another, is there a performance shop near you? They usually have them. Don't get the Allen head ones.
Weld ligs would need to be 1/2 x 20
J
jimfitzgerald
6,672
  • Sep 22, 2005
You need new lug bolts to be legal. You also need wheel spacers to get over the brakes. I originally went with 3 inch studs and 7/16 wheel spacers, but when the rules changed, I got 1/2 inch hubcentric/lugcentric wheel spacers from Maximum Motorsports. I also had to switch to 3 1/2 inch lugs, also from Maximum Motorsports.
1/2 inch wheel spacers
http://www.maximummotorsports.com/spacers.asp
Arp studs:
http://www.maximummotorsports.com/wheelstuds.asp
forpit2000gt
2,490
Columbia, SC
Sep 22, 2005
  • Sep 22, 2005
Arp studs:
if racing that is true, most tracks don't do a lot of checking around here unless sub 11s. The longer studs are better and not very hard to install.
Jim, did you have to use spacer on the rear or just the front? I only had problems with the front.
J
jimfitzgerald
6,672
  • Sep 22, 2005
If you're not racing, you don't need Welds. Only on the front to get over the front brakes. It's an NHRA requirement that the threads of your lug nuts (the hex portion) grab onto the lugs by a distance equal to the diameter of the lugs. It's a requirement at any NHRA track. Not only that, it may save your life or the life of the guy in the other lane.
blackink00
Mar 30, 2005
545
Tempe, AZ
Sep 22, 2005
  • Sep 22, 2005
Arp studs:
im only doing the rear but my fronts i have baer brakes with 13" rotors so those wont fit. anyways they have like LH and RH lug nut and so on. i wanna get the weld lug nuts. can somebody give me a part number?
SOLD SOLD!!!! 1993 Notchback Roadracer For Sale. She's a beast!
  • Boydster
  • Apr 25, 2025
Fox Body Mustangs For Sale (1979-93) Apr 25, 2025
Boydster
For Sale 94 Cobra 408w AOD Project For Sale
  • Labora
  • Oct 11, 2024
2K
SN95 Mustangs For Sale (1994-04) Aug 17, 2026
Labora
SN Mustang Magnum T56 swap
  • revhead347
  • May 24, 2024
  • 1994 - 1995 Specific Tech
7K
1994 - 1995 Specific Tech Jun 28, 2026
GearHeadGuy
On3 Performance Install Tips
  • flstang65
  • Dec 15, 2019
12K
1996 - 2004 SN95 Mustang -General/Talk- Mar 17, 2023
atomicfox236
A
Drivetrain 33 spline SN axle with ABS and parking brake build
  • revhead347
  • May 12, 2020
4K
1994 - 1995 Specific Tech May 12, 2020
revhead347
