Quick question about an MSD box
Black1987Stang
1,422
Jersey Shore
I got a MSD6t im pretty sure its called, can this be used on a stang? Ive been reading about it and all i saw the difference was that it has better wire and vibration insulation inside since its made more for offroad applications? I noticed its a little smaller than my 6AL, would this work on stang? (and no im not replacing it with my 6al)lol
6T Circle Track Ignition
121-6400
The internal components and functions of the 6T are identical to the 6A except for two additional features; special modifications for vibration dampening with internal bracing and rubber shock mounts are incorporated along with a special connector that accepts the MSD Soft Touch Rev Control (121-8738), the Soft Touch Engine Control (121-8968). An RPM module selector (121-8670) can also be used in conjunction with these rev controls. 50-state legal via EO#D-40-26.
(Odd-Fire V6 use P/N 6446)
OPERATING SPECIFICATIONS
Operating Voltage: + 10-18 VDC, Negative Ground
Current Requirements: 5 Amps-5,000 RPM, 10 Amps-10,000 RPM
RPM Range: 15,000 RPM with 14.4 Volts
Spark Series Duration: 20° Crankshaft Rotation
Energy Output Max: 105-115 Millijoules Per Spark
Weight And Size: 3lbs., 8'' L x 3-1/2'' W x 2-1/4'' H
Voltage Output Max:Primary - 460-480 Volts, Secondary - 45,000 Volts (Blaster Coil)
heres some info on msd6t
121-6400
don't know much about these but we can compare and bump back to top and see if anyone with experience with this will reply.above is the 6T and below is the 6AL. ANYONE ARE THESE 2 INTERCHANGEABLE.
MSD 6AL IGNITION BOX
MSD IGNITION 6420 Add to cart to see your low price
Manufacturer
MSD IGNITION Part Number
6420
Description
The 6AL shares the same proven circuitry of the 6A with the addition of a built-in adjustable rev limiter. The combination of powerful sparks with the safety of a Soft Touch Rev Control is what makes the 6AL the most popular ignition control in the world.
MSD first developed the Soft Touch rev control to prevent overrev damage to your motor in the event of a missed shift or driveline failure. The rpm limit is adjustable in 100 rpm increments with MSD’s plug-in modules. When the engine reaches your selected limit, the Soft Touch circuitry begins dropping the spark to various cylinders. On the next cycle, these plugs are fired again to prevent fuel from loading up in the cylinder. The result is a smooth and accurate limiting action without backfires or roughness.
The Soft Touch Rev Control also opens the door for you to add rpm accessories such as a Two Step Rev Control. A Two Step allows you to set two rpm limits, one for a holeshot rpm and another for overrev protection.
The 6AL is supplied with rubber shock mounts and modules for 3,000, 6,000, 7,000 and 8,000 rpm.
MSD 6AL Ignition Control
w/Rev Limiter, 4, 6 (even-fire only) 8-Cylinder
PN 6420
Operating Voltage: +10-18 VDC Negative Ground
10 Amps-10,000 RPM
Spark Duration: 20° Crankshaft Rotation
Energy Output Max: 105-115 mJ Per Spark
Weight and Size: 3 lbs, 8"Lx4"Wx2.25"H
Voltage Output Max: Primary: 460-480 Volts
Secondary: 45,000 Volts (Blaster Coil)
The 6T and 6A use the same board, with the only difference being the 6T has a harness coming from the board that will allow you to run an external rev limiter. So pretty much you use have the option of using the 6T as a 6A or 6AL.
