quick question about intake install
  • Thread starter Thread starter mob
  • Start date Start date Feb 17, 2009
mob
the guy who hits on his mom
20+ Year Stangneter
Oct 3, 2003
2,566
136
104
Dallas, TX
Feb 17, 2009
  • Feb 17, 2009
Ive done this install twice but I forgot, do I need to put threadlock or antisieze on the lower intake bolts?
And where would you guys put the blue silicone? I havent gotten my gaskets yet but if the front and back gaskets are cork should I still put silicone on them? Or should I ditch them and just use silicone, what if there rubber? And I know to put silicone around the coolant passeges but should I do it on the head side and intake side or just the intake side?
Foxfan88
My Grandpa has great wood.
Sep 13, 2004
2,487
Miami, Ok
Feb 17, 2009
  • Feb 17, 2009
anti-seize doesnt hurt so why not?
as for the sealant on the gaskets, i usually just put them around the water passages on the head and the intake (both sides of gasket)
and for the end seals, silicones doesnt hurt so why not?
Wallzy
128
Orlando, FL
Feb 18, 2009
  • Feb 18, 2009
I put a very thin coat of silicone on both sides. I also like to use thread lock on the threads if i'm not using a lock washer on top of a flat washer, but i don't think that you would have a problem with a dab of silicone there either.
Walz
Maryland Stang
1,656
30
39
Greenville, NC
Feb 18, 2009
  • Feb 18, 2009
Put nothing on the intake bolts. Clean up the threads on the bolts and chase the threads in the heads. That's all you should do. Have you ever read those stories from people who have broken intake manifolds but were using a torque wrench and proper techniques? It's because they lubbed the bolts. When you lube the bolts it makes them easier to turn and you can overstretch the bolts to the point of breakage before you reach the click on the torque wrench. Ford specs the bolt torque assuming the bolts will be installed dry. To get a lubbed bolt spec you would need to measure the dry bolt stretch and then install the lubbed bolts to the same stretch .
Chuck the cork gaskets and get a can of Permatex "The Right Stuff" and lay down a good 3/8" bead of it instead.
Put Permatex sealer around all of the water ports.
66sprint6
131
Feb 18, 2009
  • Feb 18, 2009
The Right Stuff is amazing! Its my new-found wonder sealant...love it. By cork, do you mean the "valley" gaskets between intake and block?
Matt
Cobra_Dusten
246
Marysville, Wa
Feb 18, 2009
  • Feb 18, 2009
Matt
yes the valley gaskets. we use goodwrench GMS(gray color) on the intakes when we do them
Engine Sick of stock TB and EGR spacer...
  • 91GTstroked
  • Dec 15, 2024
Fox 5.0 Mustang Tech Dec 19, 2024
General karthief
M
Resolved 1988 Foxbody - Overheating Summer
  • MDrisc
  • Oct 26, 2025
Fox 5.0 Mustang Tech Jul 17, 2026
fasterthangas
F
water pump installation questions
  • B0udreaux
  • Feb 5, 2026
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 28, 2026
General karthief
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 19, 2026
mattcrp1
M
L
Engine Need help diagnosing 2 dead cylinders
  • lvgnmz
  • Feb 13, 2025
Fox 5.0 Mustang Tech Feb 13, 2025
Mustang5L5
