Quick question about rear brakes as I change rotors/pads.
5spd GT
"the 5.0 owns all"
9,516
Arkansas
I had no problems swapping over the front rotors and pads and using a C-clamp to compress the caliper, but the rear calipers are very hard to push in.
Am I missing something?
Is there a way I can bleed off the pressure?
Thanks for any tips.
The tool is just a small metal box. You can buy it for a few dollars, with the expectation of needing it again in the future.
The box is too small for our rear rotors, at least the one that I have is.
I bought the tool from Harbor Freight for like $20 almost half price than autozone. There was no way that pliers would have turned mine back in. They were really hard at first to turn.
Edit: I'm talkin about 1994 up..............I had a Foxbody Saleen and the Box worked on the rear pistons. Not sure what brakes you are doing?
I've used the box on the SN95 calipers. It works, but the tool that compresses as you turn is great.
Anti-rattle clips go ont he side of the u-bracker. One on each side and then you slide the pads on.
I have pics on my home PC...i'm at work now
