quick question on aluminum d/s yoke spline!
ADRENLN
2,342
NJ
i have to throw in an aluminum d/s. i see them advertising 31 spline yoke aluminum d/s. is this the same as the rear axles and posi unit? does it have to match the carrier you have or what?
for the stock 28 spline rear, what would you need as far as the aluminum d/s?
thanks!
thanks!
The 31 splines are referring to the yoke, not the axle shafts.
You want to buy a FRPP M-4602J, provided you have a 5 spd. If you have an auto, you need to swap the youke from your stock D/S
