  • SN95 4.6L Mustang Tech
quick questionabout general engine sizes (nubie needs help)
  • Thread starter Thread starter turbokid
  • Start date Start date Nov 21, 2004
T
turbokid
113
  • Nov 21, 2004
hey guys when we say 4.6l. is that measuring volume of the block???
thanx guys
lazerred02
190
FT Stewart, GA
Nov 21, 2004
  • Nov 21, 2004
thanx guys
It measures the cylinders if I am not mistaken, thats why when someone gets there engine bored the displacement (liters) goes up.
CanadaStang
2,093
Mb
Nov 21, 2004
  • Nov 21, 2004
Displacement is the volume of air "displaced" by the pistons during a single engine cycle. In terms of a single cylinder, displacement is the volume of the space traveled by the piston. The two factors that make up engine displacement are bore and stroke.
To calculate the displacement of an engine, first calculate the displacement of a single cylinder. The formula for the volume of a cylinder:
V = hr2
where h is the height of the cylinder and r is the radius of the cylinder (halfway across). If given the bore (diameter), multiplying it by ½ (dividing by 2) will yield r. h is expressed as stroke thereby giving the formula for engine displacement:
Displacement = Stroke * * (Bore / 2)2 * [# of cylinders]
Note that when Stroke and Bore are expressed in inches, displacement is solved in units of cubic in (ci). If Stroke and Bore are expressed in mm, then calculated displacement (in cubic mm) must be divided by 1000 to be expressed in cubic cm (cc), which is the same as milliliters (ml). Also note that engine displacement is normally expressed in liters (l) by dividing the displacement in cc once again by 1000. Your 4.6L engine is actually 4593cc but is rounded out to 4.6L
tomustang
Psychotic Member
3,434
McLean Hospital
Nov 21, 2004
  • Nov 21, 2004
V = hr2
n3rd.
T
turbokid
113
  • Nov 21, 2004
thanx a lot guys i guess i got more den what i needed to know out of this!
thanx again
P
Pitch Black
369
TX
Nov 21, 2004
  • Nov 21, 2004
tomustang said:
n3rd.
No, copy & paste
G
Fox Tire Size for 16" Pony Wheels on 1984 LX Convertible
  • gw7
  • Jun 24, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 25, 2026
Qtrhrse23
I
Engine Help requested in identifying how to resolve engine light issue
  • Ianslaney
  • Oct 4, 2026
SN95 4.6L Mustang Tech Oct 4, 2026
Bullitt347
  • Gulftown980x
  • Jul 29, 2026
squeak93
M
Help! 2003 GT misfire when hot
  • Modular03
  • Feb 10, 2026
SN95 4.6L Mustang Tech Feb 13, 2026
Mustang5L5
water pump installation questions
  • B0udreaux
  • Feb 5, 2026
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 28, 2026
General karthief
