Quick radiator cap question...
  • Thread starter Thread starter Insane3D
  • Start date Start date Aug 1, 2005
I
Insane3D
310
  • Aug 1, 2005
I'm in the process of ordering a radiator cap for my Griffin 31 x 19, and I had a quick question. I know the stock cap is a 16lb cap, but the one I'm looking at is a 17lb unit. My question is would the extra 1psi make a difference in anything? My guess is no.
This is the cap in question...
http://store.summitracing.com/partd...&part=GRI-KM84&autoview=sku&Ntk=KeywordSearch
Thanks guys...
Rick 91GT
Mustang Master
95
99
PA
Aug 1, 2005
  • Aug 1, 2005
With a good aftermarket radiator that has metal tanks (not plastic) you can actually go higher which will rasie the boiling point. Ron Davis recommended a 18lb-21lb cap on there alum radiator that I used.
2002BLGT
Well-Known Member
Dec 18, 2003
2,945
Bedford VA
Aug 1, 2005
  • Aug 1, 2005
1 psi = 3 more degrees before it boils ..........16lbs cap boils at 260 degrees
18psi = 263 degrees
not that big a deal IMO..............
I
Insane3D
310
  • Aug 1, 2005
Thanks for the info. The Griffin 31 x 19" I have I would consider a " good aftermarket radiator", and it's 100% aluminum, so I'm assuming the 17lb cap should be fine?
What are the advantages to raising the pressure and boiling point?
Euphoric306
905
  • Aug 1, 2005
ur engine can get warmer before the coolant boils... when coolant boils, it overflows into the reservoir then when engine cools back down, coolant gets sucked back into system by vacuum in radiator
really a fool-proof system if there's no leaks
17 lb cap will be fine, u dont even need the higher boiling point if ur cooling systems working fine, because the engines never supposed to get that hot
K
Kerpal
400
  • Aug 1, 2005
I have the Griffin 31x19" radiator, and I used this 16lb cap: http://store.summitracing.com/default.asp?target=egnsearch.asp&N=400030+303919&autoview=sku
I'm sure you will be just fine with the 17lb though... I probably would have got that one myself had I seen it on Summit, that's kinda cool looking.
Nice choice on the Griffin, you'll love it, cools like a bad mofo and looks nice under the hood as well.
90mustangGT
I felt sorry for girls because
2,773
17
89
Dallas, GA
Aug 1, 2005
  • Aug 1, 2005
Be carefull when using higher PSI caps if your running a heater core.
Some also say that the higher psi's help cooling effeciency. I havn't seen any proof.
BaXTeR3221
917
Orange County, NY
Aug 1, 2005
  • Aug 1, 2005
18psi = 263 degrees
Your math is a little off, 18psi would equal 266 degrees. Still doesn't make a difference, but I thought I'd correct it anyway
2002BLGT
Well-Known Member
Dec 18, 2003
2,945
Bedford VA
Aug 2, 2005
  • Aug 2, 2005
LOL , just noticed that , but still , big deal right ....
I
Insane3D
310
#10
  • Aug 2, 2005
  • #10
Yeah, I'm pretty psyched to get it in. I'm doing a whole cooling system upgrade, and I'm pairing it with the Ramcharger fan and some other goodies.
Thanks for all the help guys...
5spd GT
"the 5.0 owns all"
9,516
Arkansas
Aug 2, 2005
#11
  • Aug 2, 2005
  • #11
I got the 16psi cap for my Griffin...just because I knew it would work fine. The 17psi would be fine as well.
M
  • mnky99
  • Sep 5, 2025
mnky99
M
Engine Cooling reservoir questions
  • R82148V
  • Oct 3, 2022
2K
Fox 5.0 Mustang Tech Oct 16, 2022
Mustang5L5
SN Mustang Magnum T56 swap
  • revhead347
  • May 24, 2024
  • 1994 - 1995 Specific Tech
7K
1994 - 1995 Specific Tech Jun 28, 2026
GearHeadGuy
N
SOLD Supercharged 1989 SSP Coupe $13,500 obo
  • notchlubber
  • Jul 17, 2018
13K
Fox Body Mustangs For Sale (1979-93) May 28, 2020
notchlubber
N
O
Progress Thread Which Radiator & Cap Test Kit To Choose?
  • oldnrusty
  • Nov 8, 2015
1965 - 1973 Classic Mustangs -General/Talk- Nov 8, 2015
oldnrusty
O
