you also need to pop out the surround that encases the door open handle... but KT is right on the rest. its pretty simple...
for reinstall though its kinda dificult to get it on AND get the door lock pin in the lil hole... i find it helps to get the front part just barely in the grooves fit the pin in the hole then put the back in place then push down.
its also a lil easier if you remove the tweeter pod first if you have a 460 (pry off the grill and remove the screw, let hand across the mirror)
Torinalth
