Quick wire connect question
89blkntch
17
quick question. I have the high amp 12v ran and the ground ran. I need to run a low amp 12v to a fuse in the car wire is ran just need to know which fuse to put it in. I don't have the fuse diagrahm under the dash or a hanes/chiltons to look at a dighrahm. If someone has pod gauges which fuse did you run it off of. I need to know so I can start the car and get the thermostat set at the temp I want the fan to kick on at. PLEASE RSVP!!!!!!!!!
I beleive this is the one.
http://www.jegs.com/webapp/wcs/store...22059_-1_10117
YOU BE THE MAN. YOU HAVE SAVED THE DAY MY FRIEND. I can now finish my inst and get on with my day. IE drive around town for a bit so I can set the thermostat to turn on around 180. YES
