Fox Quiet/sleeper muffler
paddyrk
71
Dublin, OH
I’m looking to figure out what kind of mufflers to get for my 91lx, I have flowmaster FX mufflers now, but am going turbo with a cutout, so I want legitimately quiet mufflers for regular driving/sleeper mode. Would still be nice to hear some cam at idle, but like a regular modern car’s level of noise, instead of having to raise my voice just to be heard. If anyone has any recommendations I’d love to hear them, I’ve considered using ‘stock’ mufflers too, would just need to verify fitment.
If you have a cutout, especially the slick electric one, stock style mufflers would be excellent.
I am running a high flow cat x pipe and Super Turbo mufflers. I can hear the stereo now, and it’s still louder than stock with some mid rpm cruising drone. The turbo mufflers are quieter (with more of a whoosh than a roar) under full throttle runs than at idle. That was a surprise.
The Dronemasters it came with were Intolerable on the road and not much quieter than open headers in town.
Just wait awhile...there'll be that guy that'll chime in and offer his testimony arguing that his catless, dumped Super 44's are not " that loud".
My catless, dumped Super 44s were so damned loud that I replaced them less than six months after I got them.
Sorry to disappoint you. :rlaugh:
For something much quieter while still not being restrictive, I'm a big fan of the Dynomax Super Turbo mufflers. I've had them on a GMC pickup and a Mustang now, and in both cases, they were MUCH quieter than a chambered muffler with no noticeable difference in power.
Don't turbochargers cut the noise significantly already?
I have Spintechs on my 90 and love them. Just enough growl that they sound good, but they don't dominate even with the top down.
Chevy designed the first turbo mufflers For the Spyder Corvairs that were turbocharged. The right size one/s should be a good match.
for,
Find some 99-04 mufflers and weld them in. Stock type muffler but a little more growl than a fox OEM muffler (if you can even find any)
Then again, finding good stock Ford 99-04 mufflers will be tough
Dynomax Ultraflow mufflers. They can get loud when you get on it, but idling they are fine. Catalytic converters seem to be the best part of the equation. They really quiet things down.
Kurt
I have ultraflos and they are OK, but still loud without cats.
I also have an engine that can cruise at really low rpm without negative consequences. So with 3.73's I can cruise in 5th gear (.64) at 40mph and be fine. At certain rpms they will still drone.
I plan on replacing them with super turbos.
My Ultraflows never drone. That's the first I have heard of that. Of course, after 25 years in aviation, my ears aren't what they used to be.
Kurt
Thank you for all the input, biggest thing is I do not have cats, I have off-road 2.5” x pipe, may just go with stock style mufflers, hopefully I can get the right size to bolt right in, or 99-04 ones if I can get the right size, I’m cheap so I don’t want to have to weld
I’ll be the third or fourth one to recommend Dynomax super turbos
Those should sound Really smooth with a turbocharger
only thing is you have to make sure you get the biggest one that will fit.
Also. The off set /off set configuration is the best flowing one as it has the curved deflectors
When you look at pics of super turbo mufflers they all show the curved plates in cutaway BUT it’s only the larger offset / offset configuration that has those plates.
The others only have dimples in case to redirect the flow back to the next pipe.
Hope my rambling helps
Couple questions -
  • What kind of x-pipe crossover are you using ( brand matters due to location)?
  • Cats - are you opposed?
  • Sound deadening - do you have any?
X-pipe design matters. Without getting too deep into standing waves and speed, the practical side is that X-pipes like the BBK have a :poo: resonance with the 302w. This will change once you introduce a turbo to the exhaust stream.
Cats def take the edge/sharpness off of the exhaust sound too. If you look for the 6cyl Jeep Cherokee replacements that are CARB EO certified, the bodies are short (4") and 1 is certified for more GVWR than any mustang. Why this particular cat? It's small, can handle the heat, isn't junk, doesn't require AIR like the stone age cats that came with our cars. And because of how small it is, you can work it into the stream wherever you want.
Mufflers - Pretty much any non-chamber muffler will be good here. The larger the case volume, obviously the better. The Fox platform is limited with muffler space under the car. I'm a fan of the Borla ProXS line personally. Pick the sound you want* (see my last point below)
Sound deadening. Our mufflers sit up under the rear seats and have a sheetmetal wall that they can resonate through. Fix THAT. Add some sticky mass like Vibro to change the panel resonance, lay some MLV like Second Skin on top of that, and then stuff under the rear seats w/ some denim insulation. Do the same for the trunk/spare tire area. Done right and you won't hear the fuel pump from inside the car anymore.
Lastly...once you get your turbo's plumed and the car tuned, download a spectrum analyzer on your phone and go drive around. You'll very quickly find the resonate frequency that is annoying (it will spike, in Hz), note the RPM that it's the worst. Use a fancy web calculator to come up with the pipe length for a 1/4 wave resonator (aka a side branch). Go to an exhaust shop, have them weld that into the mid-pipe. You mentioned cut outs....put the cut out at the end of the resonator pipe and you'll get the best of both worlds.
  • Useful
Reactions: 7991LXnSHO
I really like this idea. I still get too much drone. After the torque boxes get reinforced, some sound absorption and a res. pipe and cutout sound great. Space is tight. Any approximations on the size of one to help kill the drone?
Here is the a very simple version of the formula:
1100ft/sec (speed of sound) divided by drone frequency (in Hz) = full wave length.
Full wave length divided by 4 = quarter wave length.
Quarter wave length multiplied by 12 = length in inches of the Helmholtz chamber required to deal with your particular drone frequency.
This is a great thread that goes way deep into the theory & some exhaust pics:
As far as attenuation goes, generally speaking the larger volume the chamber is, the greater the reduction. It would prob be easiest to use the same diam pipe as your current exhaust. Best part is, once you get outside of that frequency band/exhaust velocity, it will get much louder again. The resonator only impacts the frequency that it's designed around.
