  • 1994 - 1995 Specific Tech
Radiator Questions Again....
  • Thread starter Thread starter go-stang5.0
  • Start date Start date Mar 1, 2004
go-stang5.0
2,244
Glenview,Il
Mar 1, 2004
  • Mar 1, 2004
Our stock radiators are aluminum right...If so the only things that I can think of that is bad is the plastic tanks. Is it really worth getting a racing radiator or is the stock one fine. I mean I run at the A in normal on our stock temp gauges on a hot summer day without A/C. So I know its hot and I need better cooling but will a racing radiator make that much of a difference if the stock one is aluminum? Also, I dunno if my cooling problem is just because I have an old radiator....It's got a huge dent in it (from when I bottomed out) and it also probably has scaling and stuff since its so old. So I'm thinking it could be that too...I dont want to spend the money on a direct fit but also dont want the hassle and ghetto installation of the summit one so if you guyz think a new stock one ($125) should do the trick let me know, or if I should bite the bullet and go with an aftermarket one. Or any other suggestions to the problem would help also.
go-stang5.0
2,244
Glenview,Il
Mar 1, 2004
  • Mar 1, 2004
where do u guyz get fluidines for cheapest.....that might sway me more towards that one....
dTas95GT
762
Woodinville, WA
Mar 1, 2004
  • Mar 1, 2004
i'm looking to replace my stock radiator as well.
i've been watching fourvalve.com. that's where i've found the cheapest fluidyne radiators so far. i was also considering either a new stock radiator or a summit racing one.
i'm still saving up for the fluidyne though. i think that'll be the best choice over all.
go-stang5.0
2,244
Glenview,Il
Mar 1, 2004
  • Mar 1, 2004
Come on someone has thoughts on this......
VibrantRedGT
"STANGNET'S PENGUIN SMACKER"
424
154
Boca Raton, Florida
Mar 1, 2004
  • Mar 1, 2004
Your running the stock radiator with a 331? Not a good investment with a new motor. Look online for a Fluidyne. Absolute radiator use to have them for $321 shipped but the demand is so high I'm sure it's gone up by now.
94GTLaserRC
Squint as you approach, lest you be blinded by my
11,178
Ernan Says "here it comes... dushbag"
Mar 1, 2004
  • Mar 1, 2004
"A" in "Normal" is like 230*!!!
Youre Asking for it with AFR's and 230*
You should be able to run 200 or lower with a good radiator and proper fan settings.
RC
94GTLaserRC
11,178
Mar 1, 2004
  • Mar 1, 2004
DOUBLE POST!!
Sorry
bjl95mustang
1,495
Austin,TX
Mar 2, 2004
  • Mar 2, 2004
Go with the fluidyne rad and put in a 180* t-stat. Also if you get a fluidyne rad make sure you use the reg green prestone antifreeze in the yellow bottle. I used some other brand of green stuff and it started to corrode my rad and block from the mismatched metals. I can't remember what the name for it is right now but it happens when you put an aluminum rad with an iron block.
onebad95
Sherriff of Bling King County
Jul 22, 2002
1,237
At the end of the track waiting for you !!
Mar 2, 2004
  • Mar 2, 2004
I just ordered and received my fluidyne from Mustangs Unlimited for $336 plus shipping. I got them to match some internet price I found.
dTas95GT
762
Woodinville, WA
Mar 2, 2004
#10
  • Mar 2, 2004
  • #10
how about "wetter water"?
bjl95mustang
1,495
Austin,TX
Mar 2, 2004
#11
  • Mar 2, 2004
  • #11
I was having problems with electrolysis when I put mine fluidyne in my car. I think wetter watter and hy-per lube super coolant all protect from electrolysis and help the cooling system. Without using watter wetter the best brand of af I think is the prestone in the yellow bottle. I didn't notice any problems with electrolysis when just using the fluid. I added watter wetter at a later time. To tell if you are having electrolysis happening in your rad all you have to do is open the rad cap with the engine cold and look to see if there is a white foam sitting there in the top of the cap area. To stop electrolysis you can go to some auto shops and get tablets that stop it also.
camaroguy72
20+ Year Stangneter
Mar 10, 2003
659
Mar 2, 2004
#12
  • Mar 2, 2004
  • #12
LOL... water wetter is the stuff he put in the radiator the same day the motor blew. Not that they are related.. just funny
94GTLaserRC
11,178
Mar 2, 2004
#13
  • Mar 2, 2004
  • #13
Isnt the stock radiator aluminum??
I use 50/50 Distilled water, Regular Yellow Prestone, and a bottle of WW
RC
bjl95mustang
1,495
Austin,TX
Mar 2, 2004
#14
  • Mar 2, 2004
  • #14
RC
Maybe it was the brand of af that I used that caused the electrolysis, I don't know. All I know is that I don't have anymore problems with it.
Engine Radiator with no shroud provision... What to do?
  • FastDriver
  • Apr 22, 2026
Fox 5.0 Mustang Tech Apr 25, 2026
FastDriver
Engine Themostat
  • Mindseye007
  • Jan 30, 2026
Fox 5.0 Mustang Tech Feb 1, 2026
86HO5.0
O
Backuplamps
  • onemore1987
  • Jun 30, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 5, 2026
onemore1987
O
Electrical Code 29 again
  • Creomod
  • Jul 31, 2026
Fox 5.0 Mustang Tech Aug 3, 2026
Creomod
M
Bad PCM?
  • MrPuffels
  • Jul 22, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Jul 22, 2026
MrPuffels
M
