Okay, I keep getting different answers on this. The previous owner of my GT tried to jack the car up by the radiator support which bent it. It doesn't effect anything, other than pushing the brake lines close together which causes them to vibrate at certain RPMs. I've talked to a few body shops and they have said it isn't worth the cost to repair, since it involves removing everything and welding a new piece on. While searching online for some front end parts (truck pulled my bumper and associated parts off when it turned a corner to sharp), I stumbled across a radiator support panel. I asked the shop about it and they said it is a bolt on piece, no welding required. But when I spoke to a few of the salvage yards that specialize in Mustangs, they again said it's welded. Now this weekend, while searching my local salvage yard for parts, I talked to the guy there and he said most of it is bolted except for for two tack welds at the top which he showed me that attach by the side fender. Said just drill the weld spot out and use a bolt here with the new panel.
So, anyone every replaced this panel before, and what is actually involved? Can I replace this panel with just bolting, or will I have to do welding, in which case I will probably end up keeping the damaged piece I have now.
