radiator support
  • Thread starter Thread starter stangman16
  • Start date Start date Jul 10, 2007
stangman16
640
San Antonio, TX
Jul 10, 2007
  • Jul 10, 2007
How do you remove the radiator support in a '66 Mustang coupe? I have ordered a new one, and I figure it's best for me to remove the motor and trans for repair/painting with the radiator support out of the way since I am going to replace it .
HistoricMustang
2,359
Confederate States of America
Jul 10, 2007
  • Jul 10, 2007
It has been 10 years since I did this but I believe it is just a matter of removing spot welds. Make sure the car is supported by jack stands on a level surface and not moved once the old support is removed.
Good Luck!
HistoricMustang
stangman16
640
San Antonio, TX
Jul 10, 2007
  • Jul 10, 2007
I'm also doing the cowl vent repair, and currently I have the windshield out and about 100 spot welds cut out so far. Should I finish that before removing the radiator support, or do you think it would be okay to support it on jack stands on the front only (or does it need to be on all 4's on jack stands?) - while also working on replacing the cowl sections?
HistoricMustang
2,359
Jul 10, 2007
  • Jul 10, 2007
Once I started the "frame off" restoration the car never moved from the jack stands and the level floor. Do one side at a time if possible.
HistoricMustang
www.historicmustang.com
geostang351
946
Danb., CT
Jul 11, 2007
  • Jul 11, 2007
I would finish one project at a time. Why have 4 going at once?
BullittStangV8
1,104
NJ
Jul 11, 2007
  • Jul 11, 2007
Because when you have four going at once, your bound to miss place parts and tools! thats why I'm currently doing 6, and constantly retracing my steps..
geostang351
946
Danb., CT
Jul 11, 2007
  • Jul 11, 2007
I would assume because of this you should be doing one at a time?
Are you being sarcastic ( I can't tell)
stangman16
640
San Antonio, TX
Jul 12, 2007
  • Jul 12, 2007
Roger that - I'll stick to 1 at a time. I ordered a Monte Carlo bar also, but it doesn't fit! (I just had to see... wasn't going to install it) Seems I need another inch in width to get the thing in, is there a trick to installing it?
geostang351
946
Danb., CT
Jul 23, 2007
  • Jul 23, 2007
Yes. The shock towers have sagged into towards one another over 40 years. Jack the car up from underneath at the crossmember. This will force the shock towers away from one another over a couple day duration as the car "relaxes". After a few days of settling, try installing the bar.
68 vert where to start?
  • 67 blueberry
  • Jul 2, 2026
1965 - 1973 Classic Mustangs -General/Talk- Jul 2, 2026
67 blueberry
Who Is Up To Date On DCC Fan Controllers?
  • BoostedRed89gt
  • Jun 15, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 26, 2026
revhead347
Paint and Body Frame rail dimensions
  • keel
  • Jan 30, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 13, 2026
keel
Engine pulling procedure on a 70 Mach I
  • Superdan
  • Jul 6, 2025
Classic Mustang Specific Tech Dec 26, 2025
Mach1 Driver
M
Fox Help
  • 93fox85
  • Mar 22, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 23, 2026
