Radiator
  • Thread starter Thread starter Opposedodie
  • Start date Start date Nov 4, 2011
Opposedodie
121
  • Nov 4, 2011
If the thermostat is stuck open will my Rad blow fluid into the overflow and on to the ground under hard loads?
W
wizwrath
34
  • Nov 4, 2011
not unless your rad cap is faulty letting coolant bypass at all times.....sounds like you blew a head gasket or something.....
4rdnut
188
  • Nov 4, 2011
If the t-stat is stuck closed it would, but you didn't say if the engine is overheating.
W
wizwrath
34
  • Nov 4, 2011
true that, we need more info.....
Opposedodie
121
  • Nov 4, 2011
Engine not overheating gets up to temp and fan kicks on cools down but will not stay at temp, fan kicks on at about 195-200 and kicks off at 130 ... Sitting in the driveway it works fine, take it for a drive and I lose fluid, after a drive sitting in the driveway I will get fluid on the driveway. New Rad, new hoses, 1 week old. stat about a month old, all new fluid 50/50 mix. Overflow tank is stock, no leaks. Driving down the road it will not heat up to temp unless I get on it , then I lose fluid.. No water in the oil, no oil in the water..
89stang1
Stroked and Juiced
730
234
74
nj
Nov 4, 2011
  • Nov 4, 2011
First thing i would try a different rad cap. If therm is not opening at your therm temp 180 or 160 whatever your using coolant will rise in rad and go into overflow but after hearing all new stuff just installed my bet is air bubble in rad and needs a burpin. Jack up car little on rad cap side make sure coolant is down a couple inches run car with heat on look for therm to open at right temp if it does not open thats your problem. If therm does open run car for a while raise and hold rpms a little look for large bubble once it burps you will notice level go down put cap on your good. good luck
f8tlfiveo
My wife likes my spool and blow-off valve.
Aug 8, 2007
1,585
102
64
Lancaster, PA
Nov 4, 2011
  • Nov 4, 2011
Are you sure that the fluid is coming from the overflow? I had issues with the weep hole in my waterpump when the seal started going bad. It wouldn't overheat but fluid would run out of the hole out of nowhere.
Opposedodie
121
  • Nov 4, 2011
Ya the water pump is also new .. The hole motor has about 1000 miles on it ...
I am going to put a another new Stat in it today, I think the new one is stuck open, its one of the safty ones that are ment to sick open if it gets hot...
89stang1
Stroked and Juiced
730
234
74
nj
Nov 4, 2011
  • Nov 4, 2011
the only way it would pee in overflow is when therm is stuck shut not letting coolant into block so it backs up in rad
Engine Coolant boiling in hose?
  • Teen'93stang5.0
  • Jun 3, 2026
Fox 5.0 Mustang Tech Jun 8, 2026
Mustang5L5
Flushing water from the radiator and block.
  • djj62478
  • Oct 7, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 11, 2026
CAMTWO1070
Engine Themostat
  • Mindseye007
  • Jan 30, 2026
Fox 5.0 Mustang Tech Feb 1, 2026
86HO5.0
Engine Radiator with no shroud provision... What to do?
  • FastDriver
  • Apr 22, 2026
Fox 5.0 Mustang Tech Apr 25, 2026
FastDriver
Resolved Got Too Hot!!!
  • PonyGTrider
  • Apr 27, 2025
Fox 5.0 Mustang Tech May 6, 2025
PonyGTrider
