Radio does not work.
Venom351R
4,548
41
98
MAINE
Is there a fuse that would go to the raido, if so which one is it? Anyone have a picture or a diagram of the fuse board and which one it is or do you think it could be a wireing problem? The raido has never worked since I got the car a few wks ago.
For a fusebox diagram, see here.
It might be easiest to pull the stereo and test the power leads (two of them) and ground with your meter.
Good luck.
Good luck.
Awesome thanks, I dont have a puller to get the raido out unless I take it somewhere to have them pull it. Im going to go check fuse 11 and see if its blown.
not sure if the stangs are the same as the F-150 but i used a clothes hanger i cut to pull my radio, just bent it like a "U" and stuck the cut into the holes and pulled out.. Like i said its on my f-150 but i think most those things are the same.
-AJ
-AJ
I just tried it but it would not work. I could feel the ends of the hanger slide deep into the slots but when I went to pull back they just came out. I tried squeezing them together and spreading them apart but it just kept comming stright out. Guess I'll have to go to a audio place and get it done.
Tonys89GT said:
Take it down the local stereo shop and drop it off along with $2000 and I bet they will fix it AND make it louder.
Yeah that would be sweet but I have a 347 to build first. The stero system will prob be the last thing that gets done but damn that stock deck needs to come out b/c I need a CD Player.
You have to push like this <-- --> with the close hanger makeshift tool to get out a ford radio. also if your car came with premium sound option it could be a blown continental, it is a small amp behind the stock sterio.
I've manhandled them out from behind the deck on other Fords but I dont know if I just got lucky. I agree that a stereo shop should do it gratis or for 5 bucks.
I didnt recognize the new (to me) username. :nice: (I've been workin on the literbike recently - crap fuel and slow jet issues). Nice (for you) to have a fresh bike with no such issues.
yeah fresh new bike up for sale to support the 347 project.
well the hanger goes in vertically so does that mean you put your fingers between the loop and push up on one and down on the other or do you push one to the left and the other to the right?
I use the Home Depot special tool - four 2" long nails. Push the nails in the holes until you feel resistance and then push all four nails out away from the center of the car. It works reasonably well and is cheap... :D
well I got it out but now I dont have a way to test the wires to see if its getting any power or not. I might be taking the car somewhere later this week to get something else taken care of so I'll have it looked at then.
Harbor Freight puts DMM's on sale for 3-5 bucks quite often. The meters work well and are hard to beat pricewise if you dont envision using it much.
While there, see if they have test lights for 1 bucks (on sale). Grab a couple if so.
Good luck.
Seems odd that you are having this much trouble with a stock system. Things like this usually dont pop up until some dummy hax the system to install his auto zone cd player. Does the car have an alarm or other aftermarket stuff that would cause issues??
I would goose test the wiring. If there's a chafed wire or an exposed wire (there's some sharp metal back there, as I recall), it could be blowing the fuse. Moving the wiring might unground the short and help with diagnostics.
Good luck.
yeah there is some aftermarket wiring in the car and it was deff a hack job that was done. It has guages in the car but I have not tracked down where the excess wiring is comming from and that would not be tied into the radio anyway. Im just heading out to work now but I'll take some pics when I get home tonight of the mess under the dash.
i would check the radio.... hook a wire up to the pos on ur batt and then put
the power and acc(shoould be red and yellow) on that wire the radio should turn on... if not its a bad radio!!!
