Radio wire help
ilovestangs
15
Im hard wiring a new cd play in my 87 2.3L coupe but I don't know what wire are what. Theres 10 wire which are:
Red (thick)
Yellow/black (thick)
Green/Yellow
Green (only one with power)
Red/White
Black/Blue
Black/White
Purple/White
Pink/Blue
Pink/Black
Blue/Purple
I SERIOUSLY need help as I have NO idea as to which are which. Any info would be so so so appreciated! Thanks :)
That would be awesome if you could check what wires are what man! :hail2:
And 89mustangGX I'm a noob and I impatiently cut the wires from the plug before the thought occured to me I should've waited and sought out an adapter.
one of us is color blind because i have different colors in my car.
-from your new player-
1.white
2.white/black
3.green
4.green/black
5.purple
6.purple/black
7.gray
8.gray/black
i had circut city do it about 2 years ago.....the factory plugs got cut off. i hope this helps-factory wire colors-
1. orange
2.green/yellow
3.pink/green
4.pink/blue
5.pink/blue
6.green/yellow...different then first
7.white/green
8.blue/white
just match the numbers up then it should work? and the red goes to red...turn on yellow goes to yellow...fused and power. and black goes to black..ground.
Coming from someone who's bought cars like that before -- the easiest and IMO best way to go would be to put the plugs back on and get an adapter. It makes things much cleaner and neater.
I already cut the plugs from the wires though...
OK--u know which ones the power wires are--so avoid those when doing the followning...
get a small battery 9-volt or a d-cel or even battery from power drill(preferred)...
and get one wire attach to the positive....then go through the other wires and see which one of them makes the speaker make a noise...u now have the wires for 1 pair---keep those separated...grab another wire on positive--and go through the others the same way...sounds goofy but is easy way..when u don't have the plug or a wiring diagram....good luck...
