raising the engine
  • Thread starter Thread starter Cobain03
  • Start date Start date Nov 18, 2004
Cobain03
996
Lexington, Ky
Nov 18, 2004
  • Nov 18, 2004
say i switch from 65 to 66 motor mounts (66 are 1 inch higher) how will this effect the rest of the car? will it matter? does the tranny need to be adjusted as well?
G
GaPonyFarm
663
Columbus, GA
Nov 19, 2004
  • Nov 19, 2004
You need to use the correct mounts for your car. Using the wrong part number will result in not being able to install the motor. The mounts won't be the same width as the mounting holes in the block.
I ran into that problem with my engine and couldn't figure out why it wouldn't work... I tried to force those d@#m mounts into position for hours! I didn't know about the different height in the mounts at the time.
Raising the engine will also throw your drivetrain out of alignment. The tranny will bind against the tunnel, and the the pinion angle will be thrown off, by the new angle of the driveshaft. A small change effects many things...
Why do you want to raise the engine?
brianj5600
1,964
Middle TN
Nov 19, 2004
  • Nov 19, 2004
Can you expand on this. What car? what motor? What frame mounts? I am looking at lowering mine. Maybe with short mounts from mustangs unlimited.
New Exhaust for 408w stroker
  • SadbutTrue
  • Sep 10, 2026
1965 - 1973 Classic Mustangs -General/Talk- Sep 10, 2026
nickyb
T
Electrical Brown Connector #31
  • ta66
  • Jul 26, 2026
Fox 5.0 Mustang Tech Jul 30, 2026
ta66
T
G
Intro and FB questions
  • gflat65
  • Nov 16, 2025
1965 - 1973 Classic Mustangs -General/Talk- Nov 25, 2025
horse sence
Hello fellow Mustang fanatics.
  • 580HP*428Cj
  • Apr 2, 2026
  • The Welcome Wagon
The Welcome Wagon Aug 18, 2026
josep4
L
95 gt engine vibration
  • lenzgt
  • May 11, 2026
  • 1994 - 1995 Specific Tech
1994 - 1995 Specific Tech May 26, 2026
lenzgt
L
