ram air with dearborn hood scoop
  • Thread starter Thread starter my70stang
  • Start date Start date Mar 15, 2010
my70stang
156
Arizona
Mar 15, 2010
  • Mar 15, 2010
hey all
its's certainly been a while for me. my mustang has been great ever since the 5.0 swap with a t-5. this summer i put the dearborn hood scoop on and it's mostly been for looks. to make it useful i want to turn it into ram air: 1. what are the specs for cutting the hood? 2. is there a kit for the carb to hood?
i was thinking i could just cut a hole and fab up an air cleaner type induction where the hood scoop can become useful
thanks for your post
RogerC62
833
11
38
Dayton, Ohio
Mar 21, 2010
  • Mar 21, 2010
dearborn hood scoop
Are you talking about the cobrajet hood scoop?
2+2GT
3,333
10
79
Southeastern Pennsylvania
Mar 21, 2010
  • Mar 21, 2010
The 68 Cobra Jet Mustang and some later Mercurys had something like that. The repro 71 Mustang Ram Air air cleaner might even do the job.
68RCodeConv
345
Houston, TX
Mar 23, 2010
  • Mar 23, 2010
A 68-73 ram air air cleaner is not cheap. Even the 71-73 fiberglass repros are going to cost you at least $500 (and probably more). Figure $1000 for the 68-70 setup. Just the seal alone is $125 if you can find one.
They are mostly for looks as you are not going to get any ram effect from a low scoop like that - just the cooler air.
Use a regular small block air cleaner and try to find a seal (maybe GM?) that will slip onto the rim. Get a 289 Hipo lid for the air filter. These air cleaners have a larger diameter than the ram air ones so you can't use that seal.
For Sale Borg Warner WC T5, Stock Bell Housing, RAM Clutch Set, Double Hump Cross Member, & Pro 5.0 Shifter
  • AeroCoupe
  • Aug 9, 2025
  • Drivetrain Parts
Drivetrain Parts Sep 7, 2026
AeroCoupe
F
Getting my old autocrosser running again
  • flightops
  • Aug 28, 2025
  • The Welcome Wagon
The Welcome Wagon Aug 28, 2025
M
Progress Thread mkk50's Progress Thread
  • mkk50
  • Aug 4, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 22, 2025
  • dan50
  • Jul 18, 2026
dan50
P
Fox Opinions Wanted- at a crossroad with my '88 GT
  • pindude80
  • Apr 18, 2025
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 22, 2025
pindude80
P
