Well, the beast has been tuned, with the conservative J4J1 program on my tweecer as a base start.. did all the driveability tweecs, and now it was time to goto the track..
my times were pretty much around the 13.7 @ 104mph range, so, that's not bad considering I didn't have sub 2.1 60's on any of those runs (no burnouts, I just wanted to test the top end of the motor for pinging, etc)..
but one thing I noticed is the car pretty much starts to feel like its out of steam @ 5000rpm.. it pulls so hard to 5k then it starts to flatten out.. the cam specs are 2600-5600 power range so I would assume it would pull to 6000 pretty much no?
the combo is very well matched, rpm2 intake, ported 6037 heads, fti cam, long tubes, etc, and the power is solid to 5k..
what I have that might be hurting me are:
(1) stock ignition, haven't put the crane one in yet (man I need a spark cutoff vs. fuel cutoff rpm limited, it hurts to hit the redline now!)
(2) stock catback, with all my exhaust flow > stock mufflers flow, could this hurt me at top end?
(3) J4J1 program, is this weak above 5k? I noticed that all the entry tables only goto 5000 rpm, so, what happens after that on the tweecer?
(4) distributor, its original, could it be loosing timing at the top end?
(5) the stock TACH SUCKS and I'm really shifting close to 6800 ?? haha (tweecer confirmed 6200rpm shifts)
So, yeah, something is killing it at 5k.. hard to explain but the pull just drops.. any ideas?
tweecer log shows Open Loop, 11.5:1 LAMBSE @ wot, crazy...
I'm going to put it on the dyno soon too.
THANKS..
THANKS..
(my previous best was 14.4 @ 97)
