Re-torquing heads
  • Thread starter Thread starter j69302
  • Start date Start date Feb 1, 2009
J
j69302
325
Feb 1, 2009
  • Feb 1, 2009
Is it ok to re-torque the heads with the intake bolted on and re-torque the heads and intake, or should I pull the intake to do this?
The heads are aluminum.
woodsnake
1,352
15
69
Hicksville, NY
Feb 1, 2009
  • Feb 1, 2009
Did the instructions that came with the heads say anything? I would think as long as you are only checking for the "click" again, you shouldn't have to pull the intake.....
J
j69302
325
Feb 1, 2009
  • Feb 1, 2009
They are edelbrock heads.. If I remember correctly it just said to re-torque them after the first startup and cool down
R
Rapid
297
Columbia, SC
Feb 1, 2009
  • Feb 1, 2009
I have edelbrock heads. I have installed them twice following the directions and haev re torqued them. Neither time did they need it.
Not telling you not too, just what I found. Make sure to clean out bolt holes, follow with a tap, and lubricate them properly.
D
D.Hearne
11,730
south louisiana
Feb 1, 2009
  • Feb 1, 2009
Never had to retorque aluminum or iron heads with Felpro gaskets.
J
j69302
325
Feb 1, 2009
  • Feb 1, 2009
If i remember right they clicked right away the first time I installed then retorqued them. Im using the same fel-pro gaskes this time so Im thinking it aint worth the trouble to pull my headers to do it lol.
M
My numbers sound right?
  • MiltP
  • Feb 25, 2026
1996 - 2004 SN95 Mustang -General/Talk- Apr 2, 2026
MiltP
M
F
Black Headlight Area
  • frwgt350net
  • May 26, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 30, 2026
Willybill32
A
Old Holley head identification???
  • Ar15cobra
  • Jan 27, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 27, 2026
AeroCoupe
Engine Re-torquing intake manifold bolts question
  • 91GTstroked
  • Feb 22, 2025
Fox 5.0 Mustang Tech Mar 1, 2025
Jarhead67
J
Timing chain, guides and tensioner installation (Possible orientation in Intake Stroke)
  • StallionMax
  • Sep 21, 2025
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Sep 24, 2025
StallionMax
