Read This if You Have a Vortech Tensioner Piece!
94GTLaserRC
Squint as you approach, lest you be blinded by my
My Vortech S/C has been out to Vortech for a month now. They just finished redoing practically all the internal parts, except the gears....Bearing case etc.
The bill is $600+ plus shipping both ways.
Main reason Jamie (tech mngr) said that those things go bad is too much tension on the pulley, very likely caused by manually over tightening.
I use to tighten down on it pretty hard.. He said it should have 1/4" to 1/2" slack.. Just thought I'd pass that on to save someone else here a large repair bill, plus over a month of downtime.
That's what friends are for. :flag:
RC
BlueOvalStangGT said:
Well how tight is tight? Really now way to tell. I used to get crazy slippage and belt dust, now with the tensioner not so much. Maybe its too tight, i dunno.
BTW, the 27th were going down to towers, its official.
Like I said above....1/4-1/2" slack. I used to make it so you could "pluck" the belt and have a little musical sound....I did this b/c the belt would flop around at idle until it heated up. Since Vortech is sending me a new pulley tenioner plate with NEW SQUARE adj. holes, I may not need that piece for awhile.
RC
eades5.0 said:
F u c k that...keep it tight as u can get it. You will not make boost/have belt dust all over your bay.
Yeah, and you can spend $700 for Vortech to redo your bearings :p
Ill be honest guys, I have NEVER had a problem seeing boost even when the belt was slightly loose...I just had some belt flopping noise where the belt vibrates near the crank pulley part of the belt.
Kevin.. yes, you measure the slack on the part of the belt that feeds FROM the Vortech tensioner TO the crank.
RC
RC
4.5years...no probs with my S-Trim yet.
RC
that and just think of teh sideways strees you are putting on the crank
premature bearing failure ,man. i say tighten until it doesnt slip, or where you can live with the slip
On my buddies S-Trimmed 95, we have to really jam on that belt to get it to stop slipping. Although it was colder out when it was slipping.
Does anyone make an aftermarket tensioner for these cars?
I actually make these, there made out of billet aluminum.
