Expired 1996 Mystic Cobra For Sale 39,333 Miles
Cobra96Mystic
1996 Mystic Cobra 39,333 miles
Located in Jefferson, GA
Asking $17,500
Call/text Paul 678-410-7620
Two custom tunes:
1st 93 octane 680.93 hp, 519.17 torque, 17.3 boost.
2nd 116 octane 757.63hp, 596.89 torque, 21.36 boost.
Engine is a 2001 4.6 32 valve cobra engine (better heads). Engine built by AAM Auto Machine. Clear title. The internals are as listed:
-Crower cams
-Ross pistons & rings (.020)
-Fed Mog bearings
-Eagle connecting rods
-Victor valve seats
-Crower retainers
-Crower valve springs
-Kellog crank
-Moroso oil pan
-Arp main studs
-Arp head studs
-302 stoker
- All other parts are new Ford oil pump, gaskets, timing chain, etc.
I also have machine shop bill breakdown of parts and work.
The car was built by MV Performance in Winder GA.
Parts bought through MV Performance include (receipts available):
-Fluidyne radiator
-Accufab throttle body
-#10 & #8 push lock fuel fittings.
-Innovators west 10% overdriven balancer
-Aeromotive fuel sump
-Flaming River steering shaft
-MSD plug wires
-8 rib pulley set up (for supercharger)
-Heavy duty belt tensioner (eliminate belt slip on supercharger)
-Full length sub frame connectors
-2.95 8 rib supercharger pulley
-3" x-pipe and exhaust
-Mac products pro dumps
-3" pipes for supercharger
-Big stuff 3 dfi (research if not sure what this is)
-Tons of miscellaneous things
Parts bought prior to MV Performance include (receipts available):
-Kooks long tube headers (1 7/8" to 3 1/2" collector) ceramic coated
-Weldon 1100A fuel pump with Weldon 100 micron before and 40 after
-Vortech ysi trim supercharger (polished)
-Vortech maxflow bv57 valve (polished)
-Ice Vex inter cooler 31x12x4
-Meziere electric water pump (chrome)
-Centerforce dfx clutch and friction plate
-Centerforce billet flywheel
-QA1 coil overs
-QA1 camber/caster plates
-D&D motorsports tubular k-member and a-arms
-Aeromotive fuel rails
-Steeda quadrant and adjuster quick release with firewall adjuster
-AFS wheels 18" (9 on front 10.5 on back)
-Nitto nt01 tires on front and rear
-Solid motor mounts
-Autometer boost and oil pressure gauges (a pillar)
-Metco upper and lower rear control arms
-4:10 rear gear
-Slotted and drilled rotors (front and rear)
-Optima battery (red top)
Parts that I have that are not being used (all are brand new)
-Hurst roll control
-Metco Driveshaft safety loop
-Mid length sub frame connectors
-Optima battery box
Chrome and polished parts (receipts available):
-Chrome k-member and arms
- Chrome QA1 springs
-Polished front calipers (not rear)
-Polished intake manifold
- Polished valve covers
-Chrome drive shaft safety loop
-Polished inter cooler, tubes, supercharger, and maxflow valve
Things you should know:
After I got the car back from MV Performance, I put about 100 miles on it and broke the original transmission (t45). The car sat for about a year and then I bought a new t56 magnum 6 speed transmission, Quicktime scatter sheild (rm-8080), urethane mount, reverse harness, replace flywheel bolts with ARP bolt kit, and had to buy a new 26 spline Centerforce friction plate (I still have the old friction plate Centerforce 10 spline with about 100 miles on it). Also a new custom driveshaft. I have not bought a speedometer gear for the transmission, so the speedometer isn't even close. I also had the engine bay painted gloss black before any work was done to the car. In October, I had another shop Kurgan Motorsports custom tune the car to its current tunes. They can be changed from your laptop. To be honest, I probably have about 500 miles on the engine in the last 4 years. I just don't have time for the car and need to sell. The car is unbelievably fast and sounds awesome. Still needs a little work. It needs a front alignment as it hasn't had one since all the work. The car is not perfect. It has a few scratches, no floor mats, needs a new shift knob for t56 (6 speed reverse over and up), and a small dent in front fender. Hood does not currently line up due to supercharger intake tube (too tall) see pictures. Have receipts for transmission parts.
CALL/TEXT PAUL 678-410-7620.
