Rear Axel Berring Saver reliablility?
90mustangGT
I felt sorry for girls because
2,773
17
89
Dallas, GA
I am refering to the berring assemblies that go in the rear end that replaces the stock berrings if they have gone bad and damaged the berring contact surface of the axel. They have the berring seal on the inside, and are lubed with moly and press in as an assembly. I work in a shop and have put a few in latley, and I'm just wondering if anyone has had any reliability problems with them? No that I have, yet, but I'm worried about them becoming a comback. I perfer just installing another axel. I put one in a 8.8 in a E150 today.
Don't know about the reliability -- but it's axle and bearing. ;)
On the Dana rear end in my car, the shims go on the backside of the carrier bearings -- so if you don't guess right on the shims for each side, to adjust backlash or change the contact pattern you have to pull the carrier back out, use a special puller to pull the carrier bearings off, then press them back on with different shims, then bolt it back in to measure everything again. Not uncommon to have to do that repeatedly...
If you mean the offset axle bearing assemblies that moves the bearing contact area to a different section on the axle....they work fine. It allows the use of axles that have the contact area worn out for quite some time (yrs.), before having to replace them. GL
Offset berring assemblies, that makes sense. Good to know, I worry about bandaid type fixes, they can bite you.
We had a guy come in and buy tires, then a couple weeks later came back for vibration problems, then about every week just kept comming back. So I guess they were going to warranty the tires out and when the tire was actually removed..... they were all filled with that green type fix a flat, customer said he read that if you put it in your tires, and you get a nail, they won't leak. Warranty voided. Fix-a-flat really f's tires up, my point is that quick fixes often cause more problems than solutions.
Thanks for the responses.
PuterAmI said:
My apologies for hijacking this thread
Where can I buy these?
Any auto part store has them...The part# is VLRP5707 or RP5707 under the Timken brand. BTW, they do work...have installed a few and no comebacks for yrs. One thing to mention though, once you use the offset bearings, and wear takes its toll....time for new axles. GL
Iv'e used them in my 86 for a couple years before selling the car. They worked fine, no issues.
Now this I dont understand, when we went to look @ my 93 to buy, on the test drive I noticed the bearing roaring in the rear of the car. Odd for the car haveing such low miles. Well I told the seller that their was an issue in the rear, he said nah it's the tires. The tires were the original GDY Eagles and were about 1/2 worn but dryrotted badly. I work in a tire/service store and know tires can make bearing type noises, but that was not tire noise. When I went down to view car I brought a set of new tires with me, guy told me it was gonna need tires to drive back to Charleston. So we installed tires and noise was still there, guy said he would pay for the tires and I can go on my way. For the price the car was still a steal, so I bought it, drove home like that.
sorry to have such a long story, but to finish this rambling on!!!!! Point is we installed bearingsavers here and they have been working fine. My car was sitting for many years before I bought it, guess the axle gear oil dripped off the bearings and allowed them to dry out????? Does that sound logical?????
Not really,... it's more of a "regular" wear and tear issue, the bearings will "eat up" the axle due to the hardness difference and friction, regardless of lubrication. Anyway...a 19 - 20 yrs. lifespan is not that bad.
I was concerned about the low miles. My stang only had 16000 miles on it. But I did have to drive it back from Orlando to Charleston, about 400 miles with that roaring noise.
