rear axle oil seal replacement
3spd on floor
1,099
Acworth, GA
hey, my rear end was leaking oil into one of my brake drums, so naturally the seal needs replacing. Well i got the brakes off and the axle out, but i cant figure out how to remove the seal from the housing. I know there is a tool to do it with, but i cant afford to buy every specialty tool that ford makes to use 1 time. Any ideas how to get it out without the tool?
Also, if the bearing is still tight and doesnt freewheel when spun its good, right?
Thanks again.
I have done this a bunch of times at the track.
Get some "channel locks" and rip the seal out, but be careful not to damage the area where the seal "seats". A piece of PVC pipe and a small hammer will help you "seat" the replacement.
Not a big deal. Grease the axle before "sticking it in" and I use a lite coating of ATV when putting the new one in.
HistoricMustang
www.historicmustang.com
