  • SN95 4.6L Mustang Tech
Rear brake adjustment
  • Thread starter Thread starter fwpeters
  • Start date Start date Apr 24, 2007
F
fwpeters
  • Apr 24, 2007
I just replaced the disc brake pads on my mustang. In the process I screwed up the parking brake mechnism on the right rear. When removing the parking brake cable from the caliper, I mistakenly removed the screw and spring that holds the parking brake lever in place. Then to make matters worse I somehow screwed up the adjustment. When I put it back together, I have to move the lever to point where the brakes are engaged. I had to do this in order to get the bolt back in to hold the tension spring.
Does anyone know how to adjust the rear parking brake so that it can be connected to the cable without activating the brakes?
K
Kilgore Trout
Fried or Broiled ?
4,749
95
134
Apr 24, 2007
  • Apr 24, 2007
I believe there is some info on this in the Haynes manual. Do you have one?
F
fwpeters
  • Apr 24, 2007
No, I don't. Are the inboard and outboard pads the same thickness?
K
Kilgore Trout
Fried or Broiled ?
4,749
95
134
Apr 24, 2007
  • Apr 24, 2007
Yes, they are the same.
Pull up on the lever, stick a thin drift or something into the hole to lock the tensioner, release the lever. This should put slack in the cables but still keep the tensioner intact. There are pictures of this in the $10 Haynes manual sold at AutoZone.
F
fwpeters
  • Apr 24, 2007
Thanks...I'm going to pickup a Haynes manual now.
H
Strange steering/brake issue
  • Haxmaster
  • Jun 2, 2026
SN95 4.6L Mustang Tech Jun 3, 2026
squeak93
P
Rear disk brake caliper parking brake adjustment
  • parrotguy
  • Oct 23, 2025
1974 - 1978 Mustang II Talk & Tech Oct 24, 2025
2Blue2
Front brakes not releasing
  • Boats90GT
  • Sep 15, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 25, 2026
Boats90GT
D
Brake & Suspension Rebuild
  • DuluthFoxbody
  • Monday at 4:00 PM
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Yesterday at 10:49 PM
ustacould
W
Front ATS brakes with Taurus rear brakes. Full parts needed?
  • Wagonized
  • Sep 24, 2026
Fox 5.0 Mustang Tech Sep 25, 2026
General karthief
