I just replaced the disc brake pads on my mustang. In the process I screwed up the parking brake mechnism on the right rear. When removing the parking brake cable from the caliper, I mistakenly removed the screw and spring that holds the parking brake lever in place. Then to make matters worse I somehow screwed up the adjustment. When I put it back together, I have to move the lever to point where the brakes are engaged. I had to do this in order to get the bolt back in to hold the tension spring.
Does anyone know how to adjust the rear parking brake so that it can be connected to the cable without activating the brakes?
