  • SN95 4.6L Mustang Tech
Rear brake pads
  • Thread starter Thread starter Grn935oh
  • Start date Start date Jun 9, 2004
G
Grn935oh
417
Tennessee
Jun 9, 2004
  • Jun 9, 2004
How difficult are the rear brakes on an 01' GT to replace? Who's done it and are there any tricks?
Thanks
Red mustang Gt 46
601
Good ol' Maryland
Jun 9, 2004
  • Jun 9, 2004
Simple but you'll need this to make it MUCH easier... http://www.harborfreight.com/cpi/ctaf/Displayitem.taf?itemnumber=40732
T
TripleBlk
312
Cape Canaveral FL
Jun 9, 2004
  • Jun 9, 2004
Yep, you can buy that Harbor Freight tool, or "rent" (free if you return it)from Autozone. They are a pretty popular tool item, so check with Autozone before you go there.
Next time I do the brakes, I will disconnect the E-brake cable - makes an easy job even easier,
stang976
853
Westchester, NY
Jun 9, 2004
  • Jun 9, 2004
do you really need one of these just to take the caliper off?
T
TripleBlk
312
Cape Canaveral FL
Jun 9, 2004
  • Jun 9, 2004
You need a way to bottom the brake piston - it has little indentations that the tool fits into. Then you screw the piston down. Old school was using a "disk pad spreader" to squeeze the piston back into the bore.
Red mustang Gt 46
601
Good ol' Maryland
Jun 11, 2004
  • Jun 11, 2004
As stated above, you'll need it to compress the piston. If you compress it without turning at the same time...ruined piston/seal...
scooter6753
101
maryland
Jun 11, 2004
  • Jun 11, 2004
they are right man....i did my rear brakes yesterday...i had to go buy that tool and even then u still need to push hard while turning the piston (CLOCKWISE) to reseat it. Im used to the old school way of using a pry bar and pushing the piston back...not so much the case here. So go buy the tool it will make life much easier for u.
CHANGING BRAKE PADS
  • Scwhitten
  • Jun 8, 2026
1996 - 2004 SN95 Mustang -General/Talk- Jun 12, 2026
nickyb
H
Strange steering/brake issue
  • Haxmaster
  • Jun 2, 2026
SN95 4.6L Mustang Tech Jun 3, 2026
squeak93
Brake pad and rotor upgrade
  • Sparky714
  • Aug 7, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 17, 2026
Sparky714
W
Front ATS brakes with Taurus rear brakes. Full parts needed?
  • Wagonized
  • Sep 24, 2026
Fox 5.0 Mustang Tech Sep 25, 2026
General karthief
Front brakes not releasing
  • Boats90GT
  • Sep 15, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 25, 2026
Boats90GT
