Rear Coilover Stiffness Question
  • Thread starter Thread starter ChromdOutDubs
  • Start date Start date Feb 5, 2008
ChromdOutDubs
268
Tavares, Florida
Feb 5, 2008
  • Feb 5, 2008
Ok i just got done installing my Strange 10way adjustables with QA1 150# springs. After i was finished installing the new upper shock cross member and and lower mounts i set the car on the ground. Its feel like its riding on solid blocks, the rear is so freakin stiff.... Is that how its suppose to be, i know for sure its not bound on anything and the shocks are not bottomed out. And the shock is set at the softest settings. Any ideas?
-AJ
DEFWISH
87
Wichita, Ks
Feb 5, 2008
  • Feb 5, 2008
i'd also like to know. from wat i've felt , c/o's are stiff as *****. friend of mine has tein drift2's on his 240track car and its STIFF.
ChromdOutDubs
268
Tavares, Florida
Feb 5, 2008
  • Feb 5, 2008
I jumped on the hatch area and it didnt even bounce/budge and im not a little guy either.... Seems like for drag racing you would want the back soft so its can transfer the weight to the back tires. These 150# springs were the ones that Wolfe Race Craft recommended me to do when i bought all this stuff.
-AJ
DEFWISH
87
Wichita, Ks
Feb 5, 2008
  • Feb 5, 2008
yeah, for drag you usually want softer rears i think. you positive you didnt maybe adjust the wrong way and go all the way stiff??
ChromdOutDubs
268
Tavares, Florida
Feb 5, 2008
  • Feb 5, 2008
DEFWISH said:
yeah, for drag you usually want softer rears i think. you positive you didn't maybe adjust the wrong way and go all the way stiff??
Yeah I'm sure, but i didn't think about how much i compressed the springs before i put the weight of the car on them... Maybe the springs are at their limit? Any rule of thumb that i should go by on how much to tension the springs?
-AJ
DEFWISH
87
Wichita, Ks
Feb 5, 2008
  • Feb 5, 2008
this is true. not sure. but you could try to back em off a little.
ChromdOutDubs
268
Tavares, Florida
Feb 6, 2008
  • Feb 6, 2008
I was told by someone today that 150# were way to stiff for my car.... Anyone running rear coilovers out there that can tell me what they are using? Thanks
-AJ
BlooDReigN
283
Calgary, Alberta
Feb 14, 2008
  • Feb 14, 2008
I run 250# springs on the rear in my coupe with the MM coil overs at all corners and I think 325 on the front. I'm thinking of going with maybe 450-500 on the front, because the front end seems like it's on the soft side for what I want, but definately way stiffer than stock or most lowering springs.
ChromdOutDubs
268
Tavares, Florida
Feb 14, 2008
  • Feb 14, 2008
I got my problem fixed now.... Thanks
Hey did you ever run your car at the track with better tires, I'm heading to the track tomorrow and wanted sometime of setup caparison to go off of.
-AJ
BlooDReigN
283
Calgary, Alberta
Feb 14, 2008
#10
  • Feb 14, 2008
  • #10
-AJ
What was the problem?
I did run it at the track, but never got a good clean run in. On my best run I still missed 4th, and the density altitude was around 6000'. I ran a 12.3@112 though.
Hoping to get some clean runs in this season.
ChromdOutDubs
268
Tavares, Florida
Feb 14, 2008
#11
  • Feb 14, 2008
  • #11
I had the suspension set to low and i didn't even notice that the post on the lifts were sitting on the subframe connectors.... Its all fixed now and got my strange 10 way adjustable set where i wanna start tweaking on them at the track.
-AJ
C
Suspension Rear suspension help
  • Clark302
  • Aug 17, 2025
Fox 5.0 Mustang Tech Aug 17, 2025
Clark302
C
Ride quality on a 1992 Foxbody?
  • stevedjarrell
  • Oct 21, 2024
5K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 22, 2024
limp
  • B0udreaux
  • Jul 14, 2026
AeroCoupe
Tightening upper control arm bushings at ride height dilemma… need some help
  • AnthonyA1234
  • Dec 27, 2024
  • 2 3
7K
Fox 5.0 Mustang Tech Feb 27, 2025
General karthief
R
  • riored97snake
  • Jun 18, 2026
  • What is it Worth?!?!?
riored97snake
R
