Rear control arms
87 black gt
70
12
18
Pulling out my rear axle, which is a 8.8 and putting in 3:73's, keeping four lug axles, car will be used for street maybe one or two times at strip, should i stay with stock arms with new busings, or stock uppers and aftermarket lowers, or aftermarket upper and lowers any suggedtion will greatly be appreciated
If you have ever pressed in control arm bushings, the answer is obvious. Aftermarket control arms come with the bushings already pressed in. The extra $100 is worth the 5 hours, the bruises, and the number of swear words it requires to remove and press in a new bushing on a quarter century old control arm.
Kurt
Kurt
Kurt
I was looking at upr
UCA & LCA with poly bushings. For the UCA, use the factory rubber ones that are on the diff. Most UCA's come this way.
I have poly bushings in all 8 locations. If you lube them right, it isn't a problem. For the OP, just lather them up in red bearing grease, and wipe off the excess once the installation is complete. I have had the same poly bushings in 2 different Mustangs over a period of 21 years, and I have never had "binding" problems.
There is no such thing as a free lunch. The factory rubber ones provide better ride quality, the poly bushings are stiffer and last longer. It just depends on which is more important to you.
Kurt
I am pulling my 8.8 currently and doing a gear swap as well (4.10's). I'll be replacing the UCA's and LCA's with non-adjustable tubular types with poly bushings, I think they're SR Performance off American Muscle. Looking at the thin, stamped flimsy LCA's that came stock on the car, these will be a nice improvement regardless of which brand/type you settle on. For the upper rear axle housing bushings I went with the factory replacement rubber.
Also +1 on pressing new bushings into the old control arms, pressing out those old upper axle housing bushings is enough of a pain to begin with!
Good luck and have fun!
Hi all. Riding the coattails on this post. Going to be swapping out my 8.8 4 lug with an 8.8 5 lug this spring. I want to make this as easy as possible so I'm replacing bushings and control arms on the new axle before it goes in the car. My problem is what control arms to use. I don't want to use stock, i want to use some thing better with poly bushings. The car will only be street driven and occasionally driven hard (by my standards). I don't want to spend to much on this purchase as I'm going to be doing 5 lug front and rear with disks and gears in the new axle.
I know there's some opinions out there... Please share
The upper control arm bushings on the axle on my car need replaced. It's been 20 yrs since I did them before.
Any tips on pressing out the old and installing the new in the axle without damaging them? Thanks guys
The sell a bushing removal/install tool for this, think you can get it through LMR.
I used and air hammer to beat out the old ones and the fancy tool for install.
Reactions: Gs1987GT
Dang they make a took for that now, so you "don't have to remove the axle from the car." I can't count how many times I have done those bushings without a tool, and never took the axle out of the car. The tool says it's out of stock right now. I just do the drill bit method. It's on youtube. Then clear out the rest with a wire wheel. Sometimes if they are really soft, you have to burn the remnants out. Just have something handy to put it out with, because you are not far from the fuel lines. It's pretty cool that there is a tool available for that now.
Kurt
It's a pretty solid tool. I have not used mine yet but it's well made and looks (from the videos) to be much easier than beating or burning. So while I'm here, any thoughts on replacement control arms? What's good / bad? As mentioned all street, no track, but sometimes driven hard (by my standards). I'd like to get opinions from the people that have some experience with these.
Please let me know.
Thanks
From what I’ve seen and read..... stay away from the LMR / American Muscle house brands! I follow a guy on YouTube who had the SVE lowers for a short period of time, and the bushings were toast already!
I think it’s a “you get what you pay for” with suspension stuff.
Rdub6, I understand what your saying. My issue is I don't know enough to know what are the house brands and what is a good brand. I'm willing to put some money into it because the last thing I want (or anyone else, I assume) is a failing suspension at any time. So if people have brands to stay away from to brands to look at that's what I'm interested in. Thanks
SVE is LMR’s brand.
SR Performance is American Muscle’s
The general consensus is that Maximum Motorsports is the authority on suspension components, with quality, well made products!
They're not the cheapest, that’s for sure, but that’s where I’ll look first when I’m ready. I only want to do it once, so I plan to buy right.
Reactions: 2000xp8
I'm hearing good things from folks here about Max Motorsport and UPR. I noticed that the Upper at MM is pretty much just a new Ford CA, but the lowers are different, the UPR ones do not have grease fittings (that I can see from the site) even though the desc of them indicates they do. I reached out to UPR support but have not heard back. Anyone know if they do have fittings?
Regarding Grease fittings, there is a lot of conversation about keeping these well greased. What about CAs from BBK or BMR, they show them with fittings. Should I be concerned about them having fittings? ( I seem to have used the word fittings a lot in this post... :rolleyes:
Kurt
That tools been around for a while now. When I did my rear axle back in 2009, I changed those bushings and used the tool. I thought it was pretty easy to use
