3 331 stang91 Member Oct 16, 2004 261 0 16 wisconsin Aug 8, 2006 #1 Aug 8, 2006 #1 I can I tell if the bushings are bad.? Is it something I would be able to see or is there some sort of test? Thanks
BlownFiveLiter have car, will race....wait, it doesn't run 15 Year Member Nov 29, 1999 3,133 18 108 Chicagoland Aug 9, 2006 #3 Aug 9, 2006 #3 You should be able to see some rubber bulging out, looking quite rotted if they're bad. I'm assuming you're referring to the upper control arms, since I see in your sig that you have the BBK lowers, which more than likely have polyurethane bushings.
